New floor in HT family room
Mikey081057
So I got a wild hair and ripped up the carpeting and old tile underneath it and decided to tile my family room.
I love the look and feel of real (porcelain) tile and decided to do the base in mosaic and bullnose and made a mosaic strip to divide the rooms in what we have in Florida called an "open floor plan".
I haven't gotten everything hooked up yet but I know I will be challenged acoustically to get the room close to what it was but will perhaps add some free standing panels and a smallish area rug to compensate for all the tile... Still have some wiring and config work to do and won't get that done till the end of the week.
My New Year's resolution is 3840 × 2160
Garage | Polk Monitor 5B's
Sub to the left? or to the right?I can widen out the 705's and put the sub inside the 705's too.
Thoughts?
Closet Yamaha M80 | 2 Polk MP3K subs| Yaqin MC100B with Shuguang Treasures KT 88's & CV181Z's | Tesla E83CC's | Marantz 2252B | Marantz 2385 |Polk SDA SRS 2.3 | LSiM 705's | -
Looks great. Nice job.
Looks awesome Mikey! Clearly you have no chillins in the house lol...
I think I would spread the speakers as wide as possible, put the sub on the inside. Wider soundstage, and sub as close to the center channel as possible.Living Room 2.2: Usher BE-718 "tiny dancers"; Dual DIY Dayton audio RSS210HF-4 Subs with Dayton SPA-250 amps; Arcam SA30; Musical Fidelity A308; Sony UBP-x1000es
Looks like you did a great job. Do you not think the room is bright, there is nothing to absorb.
Haven't hooked anything up yet but I expect it to be brighter for sure.... I am going to experiment with some room treats and maybe a small rug... I think I am going to move the sub inside.... I am also considering 2 smaller subs....The PB-13 is a BMF and limits placement options but it is a ported BEAST of a sub... Might consider selling it tho...
That sub is freaking huge!afterburnt wrote: »They didn't speak a word of English, they were from South Carolina.
Village Idiot of Club Polk -
I have a fairly "lively" room for my home theater gear too. Hardwood floors and windows all around with wood blinds over them. I found a couple of smaller subwoofers (SB2000s) between my LSiM707s worked better than one larger subwoofer. The SVS Soundpath feet helped a lot to prevent things around the room from rattling.
There's not much that can be done with the room above from what I can see. A rug in front of the system may help, but those windows are going to be reflecting as much if not more than the floor is. If it were me, I'd just let the auto calibration work and leave things the way they are. The LSiM series is not an inherently bright speaker, so that may help too. I would also not bother trying to set that system up to optimize two channel. A lively home theater room can be a good thing! -
I talked to SVS this AM and asked if they would extend to me the dual price if I bought a second SVS SB4000 and then I would go dual subs... That ported Pb13 Ultra is too frikken big and appropriately named... because it is like Pb (lead).
They would offer me a 5% (Like $75)repeat customer discount but I sent him to his leader to see if I could get the full $200 that I would have got if I would have ordered them within 1 year of each other.
We'll see!
So SVS called me back and gave me a $200 discount off of the SB4000 and I ordered it.
The SB 4000 doesn't dig quite as low as the PB 13 but it will work fine for HT...
The folks at SVS customer service are GREAT... I'll just leave that there.
Now to sell the PB13 Ultra BMF subMy New Year's resolution is 3840 × 2160
Mikey, Your new floor looks great! I'm not a big fan of carpet either, other than it helps with sound absorption. Always trade offs, I'm sure you'll have the room sounding very good.
Seal the grout if you haven't done so already. I say sub to the right in the corner.[
Going dual SVS SB4000'sMy New Year's resolution is 3840 × 2160
Beautiful looking room; good luck to you getting your new subs dialed in
Electrician coming tomorrow to install ded. 20A and to run some new speaker cables to the rears... In the old setup I had the cables under the carpet and thru some grooves in the old tile / grout lines which served ok... Now getting 2 runs of AQ 14/4. for the rears and sides. It will be 7.2 when done....My New Year's resolution is 3840 × 2160
Mikey081057 wrote: »So SVS called me back and gave me a $200 discount off of the SB4000 and I ordered it.
The folks at SVS customer service are GREAT... I'll just leave that there.Mikey081057 wrote: »Going dual SVS SB4000's
Nice floor!
The one thing that's better than a great sub is two of them! Don't forget the shallow roll-off of sealed vs. ported. You'll have plenty of low end at all seats!
I'm sure you plan to put both inside of the L& R speakers. However, be sure to try different placement options if possible. Like opposed walls, corners, etc...
Also, did you consider the SB-3000? Its smaller, $500 cheaper, overachiever that might make one consider three of them vs. two SB-4000's for the same money. Two up front off one output, and one behind the the listening position off the other output.
Its gotten great feedback : https://www.soundstageaccess.com/index.php/equipment-reviews/977-svs-sb-3000-subwoofer
SB-3000 15.6”H X 15.2” W X 17.8” D - 54.5 lbs
SB-4000 18.3”H X 17.8” W X 20.9” D - 102.3 lbs
I'd take dual SB4000 over a single PB13/16 any day. Yes the PB might dig a little lower but the dual subs will be a lot more even.When I was a kid my parents told me to turn it down. Now I'm an adult and my kids tell me to turn it down.
Working Warehouse; Yamaha A-S301, Sony DVP-NS3100ES for disc Plok TSX550T SVS PB2000 Mini tower PC with 400GB of music -
So added a dedicated 20 amp quad behind the cabinet... Got the new speaker wires run and I terminated them today and set up the system with 1 SB4000 on the right... I ran the Audessy XT32 utility . The second SB 4000 will get here on Monday.... The subs will be inside the fronts. I have the single SB 4000 configured for now... 2 will definitely be rockin' the slab
Nice floor!
I had an existing SB 4000 so only had to add 1 more...My New Year's resolution is 3840 × 2160
Well Duh!!! Silly me... Heck yeah only makes sense to add another. Enjoy it!Mikey081057 wrote: »I had an existing SB 4000 so only had to add 1 more...
Mikey081057 wrote: »So added a dedicated 20 amp quad behind the cabinet... Got the new speaker wires run and I terminated them today and set up the system with 1 SB4000 on the right... I ran the Audessy XT32 utility . The second SB 4000 will get here on Monday.... The subs will be inside the fronts. I have the single SB 4000 configured for now... 2 will definitely be rockin' the slab
How much did that run you? I am going to need the same for my new room. -
Electrical wire/parts about $70
Audio wire and parts < $400
My neighborhood electrician and his helper $100/ hr. (cash) $400...
He ran the wires and did the electrical terminations and I did the audio terminations.
All in about $900 ish...My New Year's resolution is 3840 × 2160
Worthwhile investment!
@Mikey081057 cool thanks, now I just need a neighbor that's an electrician.
Nice looking room.Yamaha RX-A2070, Musical Fidelity M6si integrated amp, Benchmark Dac1, Bluesound NODE 2i, Audiolab 6000CDT CD Transport, Parasound Zphono USB Phono Preamp, Fluance RT85, Ortofon 2M Bronze, Polk L600's, L400, L900's, RC80i's, SVS 3000 Micro, Audioquest Interconnects and Digital Cables, Nordost Silver Shadow Digital Cable, Cullen Gold and Crossover Series Power Cables, Douglas Connection Alpha 12AWG OCC Speaker Cables, Douglas Connection Alpha Analog Interconnect Cables, Douglas Connection Alpha 11 OCC Custom Power Cable, Signal Power Cable, Furman PL-8C 15 Power Conditioner, Sony 65" 900F, Sony UBP-X700, Fios, Apple TV 4K, Audioquest Chocolate HDMI Cables. SnubWay, Main Stream
2nd SB4000 Ultra arrives today.My New Year's resolution is 3840 × 2160
saweeet!!!
Got the new sub and re configged everything... gettin' there...I'll do some tweaking but overall Audessy set it up pretty good.
Looks awesome. Like the pool in the background!!!_____________________________________________________________________________________________
DAC: Bricasti M1SE
Pre/Pro: Marantz AV8805
Subs: 2 - Rythmik F25's
Room Treatments: GIK Acoustics -
On my way Mikey *grabs popcorn*
