What speakers are these?
afterburnt
in Speakers
Allison Acoustics IC20
I read up on them thar speakers and they sound about as complicated as wImings. I guess they chose the right name for them. If I were to ever get a set I would put them in the kitchen.
seems plausible. They look like Allison Ones on steroids (or acid, as the case may be).
Roy Allison had it goin' on, loudspeaker-wise (and IMO, of course).
Doc, is Roy Allison "dearly departed"?
Yes, he died just a couple of years ago -- 2017 IIRC.
He was one of the last of the AR gang and, by all accounts, a fine fellow. He lived here in NH, but down on the other side of the state (near or perhaps on the seacoast... yes, NH has a seacoast).
EDIT: 2016 https://audiokarma.org/forums/index.php?threads/roy-f-allison-1927-2016.706039/
He and Villchur both lived to fairly ripe old ages; there was a great interview with them in... umm... Stereophile (I think).
EDIT: Yeppers. 2005.
https://www.stereophile.com/interviews/105villchur/index.html
AR gang?
Seacoast, you sure that ain't Lake Ontario or something? -
afterburnt wrote: »AR gang?
Acoustic Research.
Villchur, Kloss, Allison -- and, by extension guys like Burhoe and, umm, the Avid (later Boston Acoustics) guy... whose name is escaping me at the moment... Andy somebody...Sorry if I'm stepping on your toes on this one Bruce, but since the vintage gurus are here I thought I'd ask. What are these?
no idea. Looks like a third-party cabinet; common in the 1950s into early 1960s. Folks bought the cabinet and loaded with whatever drivers they wanted to/could afford to.
Actually, the non-mitered trim suggests DIY, maybe?
No problem no toes. I have no arms or legs, they use me for third base. -
afterburnt wrote: »
Just be glad one leg's not shorter than the other, then folks might call you Eileen.
Well, I guess that's why they keep calling me Shirley. -
I don’t know bumpLiving Room 2.2: Usher BE-718 "tiny dancers"; Dual DIY Dayton audio RSS210HF-4 Subs with Dayton SPA-250 amps; Arcam SA30; Musical Fidelity A308; Sony UBP-x1000es
afterburnt wrote: »
Look like a placement nightmare.Political Correctness'.........defined
President of Club Polk -
Three 20 amp circuits. -
What model are these? Help -
Hauntedone wrote: »What model are these? Help
Ones that you probably should buy. 2.3s, although it doesn't appear to have the SL3000 tweeters that the 2.3TL would have. -
Those are SDA SRS 2.3TL's with the original SL3000 tweeters.Political Correctness'.........defined
Whoops.
I had mine on.Political Correctness'.........defined
Simple switch out of tweeters?
For the RD0198? Yes.Political Correctness'.........defined
Last question. If in good condition (fully functioning) what are these worth?
They are basically worth what someone is willing to pay.
ebay is the best resource for pricing research -
Whatever the seller is asking.Political Correctness'.........defined
in at 200.00Most people just listen to music and watch movies. I EXPERIENCE them.
--Mark Twain. -
Varies from state to state. California or New York. $75. Iowa and Oregon $8,000Gustard X26 Pro DAC
Hauntedone wrote: »
Did you buy them already? -
afterburnt wrote: »
How much for the dog?
The Notorious RBG called and said she wanted her glasses back...
Offered $2200. Waiting for a reply
