3mm to RCA interconnect cable
kevhed72
Something decent such as AQ...something shorter than .5 m for our awesome Alexa Im stuck with...such an eyesore:
well... at least the CA-610II is no eyesore.
On-topic: sorry, I cannot help. Everything like that here is Radio Shack grade.Post edited by mhardy6647 on -
Thank you sir....its been in the shop a fee times and unfortunately the original issue just started coming back. At times....the left channel has no volume. When this happens the fix is usually to turn power off and on again. Also at times there is a bit of static in this channel and it will go out. I should mention the volume/balance knob was bent at one time and my repair guy was able to straighten back pretty close to where it was. Any ideas?
I have one that will work but it's 3m long. Fresh off the boat from China. It was a good quality one with gold terminals that I used to connect my laptop to my receiver before I discovered the world of DAC's and USB cables. PM me your address and I'll send it to you. If it doesn't work for you just regift it.
It's like this only the RCA's are straight.
https://www.ebay.com/itm/Mini-Jack-3-5-to-Dual-RCA-Audiophile-Audio-Cable-PC-Car-Speaker-L-RCA-3-5mm-AUX/153681225549?hash=item23c81d674d:m:mjfoKMBD58vrW45QMeeFpUAGustard X26 Pro DAC
Buy one on Amazon for $5, After all, it's to connect a **** in the box. nything else would be a waste of money.Main System 2.2:
Proton AA-1150 ~ Yamaha C-4 ~ Furman Elite-15 DMi ~ Sennheiser HD600 ~ Monitor Audio Silver RS8
(2x) Martin Logan Dynamo ~ Marantz CD5003 ~ Squeezebox Classic ~ Music Hall dac25.2 ~ Sansui D-X111R
Dual 1229/Acutex M312 III STR ~ Music Hall mmf-5.1/Goldring 1012GX ~ Music Hall Cruise Control 2.0
Home Theater 5.2:
Yamaha RX-V800 ~ Furman Elite-15 DMi ~ Polk Audio RT55i ~ RT35i ~ CS400i ~ (2x) PSW450
Winter Residence 2.1 (laptop system):
Yamaha RX-485 ~ Squeezebox Classic ~ Topping D30 ~ EPI M90 ~ Dayton Audio SUB-1200 -
Thank you for the generous offer but that length is too long. One of the reasons I keep hanging out here....I have one that will work but it's 3m long. Fresh off the boat from China. It was a good quality one with gold terminals that I used to connect my laptop to my receiver before I discovered the world of DAC's and USB cables. PM me your address and I'll send it to you. If it doesn't work for you just regift it.
NP.Gustard X26 Pro DAC
Check the Zu Audio cable sales on eBay. I use one of their 0.5m cables with the setup you are seeking with good results.integrated w/DAC module Gryphon Diablo 300
server Wolf Alpha 3SX
phono pre Dynamic Sounds Associates Phono II
turntable/tonearms Origin Live Sovereign Mk3 dual arm, Origin Live Enterprise Mk4, Origin Live Illustrious Mk3c
cartridges Miyajima Madake, Ortofon Windfeld Ti, Ortofon
speakers Rockport Mira II
cables Synergistic Research Cables, Gryphon VPI XLR, Sablon 2020 USB
rack Adona Eris 6dw
ultrasonic cleaner Degritter -
Have the protection relays been cleaned or replaced?2 Channel - Polk SDA-2BTL, Triad SA1, 1000VA Dreadnought, Ryff streaming via Control4 for Qobuz lossless audio -
I can check
I can definitely take a look if I knew where to look on the board....what do they look like? Im putting the less desirable R500 into service until ai can get it fixed due the volume issue is annoying as he!!ambiophonics wrote: »Thank you sir....its been in the shop a fee times and unfortunately the original issue just started coming back. At times....the left channel has no volume. When this happens the fix is usually to turn power off and on again. Also at times there is a bit of static in this channel and it will go out. I should mention the volume/balance knob was bent at one time and my repair guy was able to straighten back pretty close to where it was. Any ideas?
