POLK AUDIO DRIVER MW6503
CARLOSSANZCUMPLI20__
in Speakers
POLK AUDIO SE PUEDE REMPLAZAR EL MW6503 POR EL MW6510 O HAY OTRO MEJOR
Hola, no, el MW6510 no es un buen reemplazo para el MW6503. Las especificaciones son diferentes y afectarían el balance de sonido. Sería mejor tratar de encontrar el componente correcto. Ha habido personas que los han encontrado en eBay.
Hi, no, the MW6510 is not a good replacement for the MW6503. The specifications are different and would affect the sound balance. It would be better to try to find the right component. There have been people who have found them on eBay.Pio Elete Pro 520
Panamax 5400-EX
Sunfire TGP 5
PS Audio GCPH phono pre
Sunfire CG 200 X 5
Sunfire CG Sig 405 X 5
OPPO BDP-83 SE
Ctr CS1000p
Sur - FX1000 x 4
SUB - SVS PB2-Plus
Workkout room:
Onkyo TX-DS898
GFA 555
Yamaha DVD-S1800BL/SACD
Ft - SDA 1C
Not being used:
RTi 38's -4
RT55i's - 2
LSI 15's
CSi40
PSW 404
