POLK AUDIO DRIVER MW6503
POLK AUDIO SE PUEDE REMPLAZAR EL MW6503 POR EL MW6510 O HAY OTRO MEJOR
  • Hola, no, el MW6510 no es un buen reemplazo para el MW6503. Las especificaciones son diferentes y afectarían el balance de sonido. Sería mejor tratar de encontrar el componente correcto. Ha habido personas que los han encontrado en eBay.
  • vmaxer
    vmaxer Posts: 5,121
    Hi, no, the MW6510 is not a good replacement for the MW6503. The specifications are different and would affect the sound balance. It would be better to try to find the right component. There have been people who have found them on eBay.
    Pio Elete Pro 520
    Panamax 5400-EX
    Sunfire TGP 5
    PS Audio GCPH phono pre
    Sunfire CG 200 X 5
    Sunfire CG Sig 405 X 5
    OPPO BDP-83 SE
    Ctr CS1000p
    Sur - FX1000 x 4
    SUB - SVS PB2-Plus
    Workkout room:
    Onkyo TX-DS898
    GFA 555
    Yamaha DVD-S1800BL/SACD
    Ft - SDA 1C
    Not being used:
    RTi 38's -4
    RT55i's - 2
    LSI 15's
    CSi40
    PSW 404
