Old Sub ?
sgoodsell
sgoodsell Posts: 1
edited September 2005 in Car Subwoofer Talk
I am trying to find specs for a EX II series sub. It says EX10 on the back, and the ser. num is EX 101443.
Post edited by sgoodsell on
  • RuSsMaN
    RuSsMaN Posts: 17,985
    edited April 2002
    1mm thick mineral filled polymer cone, injection molded polypropylene dustcap, rubber surround.
    4 layer, 2" voice coil, vented pole piece.
    4 ohm, 20-400Hz, 150 wrms-300 peak, 92dB spl
    Enlcosure sizes:
    Sealed- .65ft
    Ported- 1.0ft port-3"x9 7/8"
    Bandpass- total 1.1ft, front chamber .5/rear .6 port-3"x9 7/8"
    Fs 32.47 Hz
    Re 3.34 ohms
    Qms 8.27
    Qes .48
    Vas .45
    Depth - top mount 4 11/16", bottom mount 5 1/16"
    Diameter - 9 1/16"
    Cheers,
    Russ
  • gidrah
    gidrah Posts: 3,049
    edited April 2002
    Good job Russ.
    And ya'all thought we couldn't merge.
    Make it Funky! :)
  • RuSsMaN
    edited April 2002
    That one was easy, first I actually used the 'search' feature, and typed in EX10. Took me straigh to a post I made quite some time ago on the same subject....
    I use the same sub in my truck, in a sealed .7ft box with 200~ clean watts, its a good sub, very musical.
    Cheers,
    Russ
  • Toxis
    Toxis Posts: 5,116
    PoweredByDodge, can you help with this one too? :D hahaha
    Sorry, it's late and I'm tired and feeling awnry.
