Old Sub ?
sgoodsell
I am trying to find specs for a EX II series sub. It says EX10 on the back, and the ser. num is EX 101443.
Post edited by sgoodsell on
1mm thick mineral filled polymer cone, injection molded polypropylene dustcap, rubber surround.
4 layer, 2" voice coil, vented pole piece.
4 ohm, 20-400Hz, 150 wrms-300 peak, 92dB spl
Enlcosure sizes:
Sealed- .65ft
Ported- 1.0ft port-3"x9 7/8"
Bandpass- total 1.1ft, front chamber .5/rear .6 port-3"x9 7/8"
Fs 32.47 Hz
Re 3.34 ohms
Qms 8.27
Qes .48
Vas .45
Depth - top mount 4 11/16", bottom mount 5 1/16"
Diameter - 9 1/16"
Cheers,
Good job Russ.
And ya'all thought we couldn't merge.Make it Funky!
That one was easy, first I actually used the 'search' feature, and typed in EX10. Took me straigh to a post I made quite some time ago on the same subject....
I use the same sub in my truck, in a sealed .7ft box with 200~ clean watts, its a good sub, very musical.
Cheers,
PoweredByDodge, can you help with this one too?
hahaha
Sorry, it's late and I'm tired and feeling awnry.Never kick a fresh **** on a hot day.
