Audio Research SP-14
rebelsoul
rebelsoul Posts: 756
edited January 2020 in For Sale (FS) Classifieds
Mint condition 8 out of 10
$1,200 Will post pics tomorrow.
Will answer any Questions and take lots of pics.
will ship double box. Don't have original box. Have original owners manual.
    pitdogg2 Posts: 26,927
    The only tube used is a 6dj8 and only in the phono stage .. correct?
  • rebelsoul
    correct
  • rebelsoul
    Stereophile said
    As far as value goes, I have to say the ARC SP14 represents the better investment. It has most, if not all, of the features the audiophile will want. It has control flexibility which the C-J PV9 doesn't even approach. It's as well made as any component I've had the pleasure to review, and is backed by a company whose reputation for good sound and quality products is legendary. In my opinion, the sound of the SP14, via line or phono, will set new standards for the industry. I can see other companies using the SP14 as a benchmark by which to judge their own products—it's that good. It is user-friendly and attractively styled, injecting its unique form of magic into the reproduction of music to a degree I've rarely experienced before. I feel it should be included in Class A of "Recommended Components." It is a very special product.
  • rooftop59
    rooftop59 Posts: 8,121
    I don’t even know what this is lol...little lean on the description!
    Game Room 5.1.4:
    Bedroom 2.1
  • maxward
    maxward Posts: 1,670
    A preamp. This one has a phono preamp built in. Audio Research preamps are usually, perhaps always, designated with an “SP” in the model number.
  • maxward
    A clarification: Their line stage preamps are usually LS-(...).
  • dromunds
    dromunds Posts: 10,093
    But isn't this one a line-stage?
  • dromunds
    Ok, one tube in phono stage; line section is all-FET
  • pglbook
    pglbook Posts: 2,258
    edited January 2020
    rooftop59 wrote: »
    Thanks to those who have provided some details about this piece. But I agree with rooftop that a Seller needs to provide a full and detailed description of an item when posting an item for sale. When I first saw this posted last night, like rooftop, I also had no idea what was being offered for sale. I copied and pasted and then googled the item name (from title of op) last night but still would like more information about it from the Seller.
    Thanks.
  • maxward
    Perhaps the seller will provide a more detailed description along with the pictures that were supposed to be posted sometime today.
  • rebelsoul
    Description: Hybrid (tube/FET) stereo preamplifier with one phono input, six line-level inputs, and two tape loops. Specifications: Frequency response: 30Hz–40kHz ±0.3dB (RIAA phono), 5Hz–50kHz ±0.5dB (line). Distortion: less than 0.01% at 2V output. Input impedance: 47k ohms standard, with user-adjustable resistance and capacitance (600pF as supplied) (phono); 50k ohms (line). Output impedance: 250 ohms (main), 1000 ohms (tape-out). Recommended load: 60k–100k ohms in parallel with 100pF (20k ohms minimum and 1000pF maximum). Phono stage gain: 66dB (to main out), 46dB (to tape-out). Phono sensitivity: 0.25mV at 1kHz for 0.5V output. Line stage gain: 20dB (to main out), 0dB (to tape out). Line sensitivity: 50mV RMS at 1kHz for 0.5V output. Output level: 2V RMS 5Hz–50kHz, all outputs into 60k ohms (maximum from main output, 50V RMS at 0.5% THD at 1kHz into a 100k ohm load with 5V RMS high level input). Phono overload: 200mV RMS at 1kHz (1000mV RMS, 10kHz). Maximum input level (line): 20V. Noise: 98dB below 5V RMS output, greater than 100dB below 1V RMS input (line), 78dB below 1mV input (phono).
    Dimensions: 19" W by 10¼" D by 5¼" H. Weight: 12 lbs.
    Serial number of unit auditioned: 40040018.
    Price: $2995 (1990); no longer available (2010). Approximate number of dealers: 60.
    Manufacturer: Audio Research Corporation, Minneapolis, MN 55430 (1990); 3900 Annapolis Lane N., Plymouth, MN 55447-5447. Tel: (763) 577-9700. Fax: (763) 577-0323. (2010). Web: www.audioresearch.com.
  • rebelsoul
    edited January 2020
  • Mikey081057
    Mikey081057 Posts: 7,127
    There is a lot of WOW factor right there folks
    Garage | Polk Monitor 5B's
  • verb
    verb Posts: 10,176
    Sweet looking pre! Love the looks of the pro/laboratory toggle switches! :smile:
  • muncybob
    muncybob Posts: 3,228
    Why would you ever need "reverse"?
    Yep, my name really is Bob.
    treitz3 Posts: 19,945
    Polarity.
  • Jetmaker737
    Jetmaker737 Posts: 1,103
    Nice pre! GLWTS
    audioluvr Posts: 5,867
    muncybob wrote: »
    Just in case you get stuck. On a genera of course?
  • rebelsoul
    Polkie special $1,100 plus shipping.
  • rebelsoul
    Are you in the chicago area then no shipping. lol you know you want it.
  • sold on ebay $1,450
