Filling space in mm6502
Am trying to find out should you fill the speaker enclosure with that plastic wool stuff for the mm6502 woofer or not.
Answers
    F1nut Posts: 51,766
    Try being more specific. For example, what model of speaker?
  • It's the Polk mm1 6.5" component mm6502
    F1nut Posts: 51,766
    Ah, car audio. That's a ball game that I don't play. That said, if it didn't come with poly fill then the answer is no.
  • Thanks heaps mate, I did fill them, now one is not filled, the other is, will let you know how it is goes
  • gp4jesus
    gp4jesus Posts: 2,019
    edited January 2020
    Try it. You might like it.
    *all connected w/Premiere ICs
  • car audio speakers normally designed to be installed in the doors. (Similar to ceiling speakers (the ones without enclosures)). I'd think they'd be congested in that enclosure.
    If you can try, do try placing fiberfill inside that enclosure. You may (or may not) hear benefits.
