Filling space in mm6502
brentflh18
in Speakers
Am trying to find out should you fill the speaker enclosure with that plastic wool stuff for the mm6502 woofer or not.
Answers
Try being more specific. For example, what model of speaker?Political Correctness'.........defined
President of Club Polk -
It's the Polk mm1 6.5" component mm6502
Ah, car audio. That's a ball game that I don't play. That said, if it didn't come with poly fill then the answer is no.Political Correctness'.........defined
Thanks heaps mate, I did fill them, now one is not filled, the other is, will let you know how it is goes
Try it. You might like it.Samsung 60" QN65Q7FAMFXZA QLED, Outlaw Audio 976 Pre/Pro, Samsung BDP, Amazon Firestick, Phillips CD Changer
*all connected w/Premiere ICs
4 dedicated 20A feeds; APC H15; 5 Furman Miniport 20s -
car audio speakers normally designed to be installed in the doors. (Similar to ceiling speakers (the ones without enclosures)). I'd think they'd be congested in that enclosure.
If you can try, do try placing fiberfill inside that enclosure. You may (or may not) hear benefits.
