Hurricane Nuts - Where to Buy Screws
    pitdogg2 Posts: 27,914
    As long as they do not get into the rubber. I tried some and the little tiny bit of rubber under the washer ended up twisting a little and about 6 months later I could see a start of the rubber surround coming up around the washer. Upon closer inspection I could see where the rubber was also micro cracking and coming away from the metal on both sides of the washer. be careful
  • jdjohn
    jdjohn Posts: 3,455
    Chuck Norris uses these, and tightens them by hand with the finger grips...no tools required. Oh, and he does it DURING a hurricane.
  • gp4jesus
    gp4jesus Posts: 2,025
    edited January 2020
    ddog wrote: »
    I use the same as F1
    Worked great..
    Ditto. I prefer the matching color, too. I’m not a “blinger.”
    Jesse: when I read “socket cap” I envisioned a bolt, not an Allen head screw. Further, I agree, washers are a good idea.
    My 2 cents
    *all connected w/Premiere ICs
    edited January 2020
    I used these button cap head bolts they have more surface area, but use smaller allen wrench.
    https://www.google.com/search?ie=UTF-8&source=android-browser&q=cap+head+bolt#imgrc=TQNXF6ujPOaMUM:
    F1nut Posts: 52,406
    gp4jesus wrote: »
    ddog wrote: »
    Worked great..
    My 2 cents
    Just calling them what the industry does.
    https://www.mscdirect.com/product/details/05524152
    edited January 2020
    Since my last attempt didn't transfer well, I use these in black on mine.
    xschop Posts: 5,919
    edited January 2020
    I used stainless domed capheads like pitdogg2's above. Unpolished, they match the billet patina of my terminal plates.
  • machone
    machone Posts: 1,588
    Used the button heads. Blackened stainless from Mcmaster Carr.
    1KVA Dreadnought
    Marantz SA 8005
    Sony PS4
  • Kryten
    Kryten Posts: 79
    Thanks for the insights and advice guys.
