Yamaha WXC50
Just got this. Pre/streamer. Going to use it for a budget 2Ch to see what it can do. Stay tuned
    msg Posts: 9,442
    $4
  • gyosa
    gyosa Posts: 699
    edited January 2020
    I have 3 of them ...
    Love them ...especially for the price.
    They sound pretty damn good .... I think you’ll be pleasantly surprised.
    Ones driving a Parasound A21 , one a B&K EX-442 and the other coax into a Cambridge 851n ..... that setup sounds noticeably better than the other 2 .
    Make sure to set it to FLOORSTANDING speakers.
    Enjoy , let us know your impressions...
    Bk
    Dayens Ampino , Yamaha wxc-50 , Polk SDA 1c’s ( my first love .. ) , Kimber Kable 4TC, Sony 42” - BEDROOM
    B&K EX-442 ( it will go in my casket when I die ... ) , PS Audio 4.6 preamp ( old school , but it still jams on ... ) , Eversolo DMP-A6 , Boston Acoustic voyager 7’s - POOL
    Parasound A21, Eversolo DMP-A8 , Yamaha wxc-50 , Kimber Kable 4vs , Salk Supercharged Song towers ( difficult choice between these and my family if I had to choose ... 😩 ) , Sony XBR-A8F 65” OLED - DEN , MAIN RIG
    PS Audio S300 - sitting in the closet for now …
    Onkyo TX-nr609 , Polk atrium 7 , Boston acoustic sound ware (4) , Boston acoustic sub , B&W center , Sharp 65” TV - PATIO
  • lightman1
    lightman1 Posts: 10,776
    msg wrote: »
    $4
    $7 and it's a deal ;)
  • lightman1
    Out of the box.... Sounds good.
    Parasound HCA 750A driving a pair of Lsi7. Streaming Spotify over Bluetooth for now.
    VR3 Posts: 28,027
    You copy me, internal dac isn't terrible for sure
  • lightman1
    Groovy! Didn't know you had one.
    VR3 Posts: 28,027
    It's good stuff, the mconnect app does mqa for tidal and it works for quobuz
    I find using wired versus wireless makes a difference
    msg Posts: 9,442
    VR3 wrote: »
    I read that in Short Round's voice, and added a Docta Jones after copy me
    treitz3 Posts: 18,325
    lightman1 wrote: »
    I do believe that this is the longest review Russ has ever done. Bravo man.
  • lightman1
    treitz3 wrote: »
    lightman1 wrote: »
    Thanks. Buy one
  • ZLTFUL
    ZLTFUL Posts: 5,640
    Damnit I need to get you your real streamer so you can get off the Bluetooth. *shudder* Judy has warped your sense of apropos.
    VR3 Posts: 28,027
    Wxc50 does now than Bluetooth, it's a very capable streamer
  • ZLTFUL
    ZLTFUL Posts: 5,640
    Trey, the problem is, Russ doesn't have a local internet connection and has to rely on tethering to his phone. He also has a NAS but no internal network to speak of at the house so the connection will be NAS-->USB-->Micro PC with MediaMonkey/MediaMonkey Remote on his phone.
    And IIRC, the WXC50 does not have a way to tether a cellular connection...only WiFi/LAN or BT.
  • lightman1
    Settle down foo! WiFi coming up soon.
  • Nightfall
    Nightfall Posts: 10,071
    Yamaha makes trash.
    afterburnt wrote: »
    Village Idiot of Club Polk
  • Mikey081057
    Mikey081057 Posts: 7,127
    lightman1 wrote: »
    Why is the room tilted like that?
    Garage | Polk Monitor 5B's
  • Nightfall
    I was just kidding. I'm a big fan. How's the new house?
    afterburnt wrote: »
  • lightman1
    Nightfall wrote: »
    ;) I know. All good here. Getting settled in and getting back to a normal life.
    lightman1 wrote: »
    Old house or I'm drunk. Not sure.
  • Mikey081057
    lightman1 wrote: »
    Nightfall wrote: »
    lightman1 wrote: »
    Perhaps both?
  • deronb1
    deronb1 Posts: 5,021
    How would this compare to the Node2 or 2i?
    mhardy6647 Posts: 33,042
    Nightfall wrote: »
    Yamaha makes trash.
    Good thing I know this is just banter.
    16013994074_3405e2a9d8_b.jpgDSC_0241 by Mark Hardy, on Flickr
    My little friends have very sensitive egos.
  • gyosa
    gyosa Posts: 699
    edited January 2020
    I considered the node ...
    I went with the Yamaha ..... 3 of them .....
    Closest thing I could find that did everything the Yamaha did was the maranta NA 6006 - at twice the price - and no 12v trigger ....
    Way more flexible , Tons of inputs and digital outputs so you can use as a transport with an external DAC , internal power supply , and biggest reason for me is it has SiriusXM- which I listen to a lot ....
    It’ll do SiriusXM In 16/44.1 - sounds pretty good.
    Although the node will do TIDAL MQA , I feel it’s not that important to me - especially since I’m using an 851n for my main critical listening rig for Tidal and fed SiriusXM via coax from the Yamaha ....
    It really is a huge bang for the buck ...
    BK
    deronb1 wrote: »
