Connecting speakers
keith allen
I have a pair of RT35i's in my bedroom that I dont use much,I was thinking about putting them on my RTi8' and hooking them together(via the second pair of binding post on the 8's).Would this be ok to do?Input please!:)
Post edited by keith allen on
Why don't you just hook them up to your B speaker terminals and turn that on?Arcam DiVa AVR300 Receiver
Outlaw Audio 755 Power Amp
Audio Tecnica lp120 Turntable
Polk Audio LSi15 Front Speakers
Polk Audio LSi9 Rear Surrounds
Polk CSi2 Center Speaker
Apple Mac Mini HTPC
Samsung HL67A750 TV -
They're different enough that I wouldn't suggest doing that, it would color the sound, cause comb filtering, let loose the Apocalypse and so on. (Just kidding about that, I'm not sure about the comb filtering.) You might be better off putting your RT35i's elsewhere and making another system.
Matt -
Some folks like the sound from stacking bookshelves on floorstanders.
Real issue is will your amp/ receiver handle the 4-ohm load that results from wiring the two in parallel, which is what you are proposing will do...
Try it at modest volumes, and see how it sounds and if your amp gets warm/ hot...More later,
Tour...
Vox Copuli
If flip the RT35is upside down and put them around 2 -> 3 feet above your RTi8s. You will add height to the sound.Win7 Media Center -> Onkyo TXSR702 -> Polk Rti70
the second set of binding posts are for biwiring and biamping, thats not how you would hook them up.
just run another wire out from your receiver or amp to the other set of speakers. like tour said tho, make sure that your amp can handle a 4 ohm load.
