Yamaha WXC50
lightman1
in Electronics
Just got this. Pre/streamer. Going to use it for a budget 2Ch to see what it can do. Stay tuned
I have 3 of them ...
Love them ...especially for the price.
They sound pretty damn good .... I think you’ll be pleasantly surprised.
Ones driving a Parasound A21 , one a B&K EX-442 and the other coax into a Cambridge 851n ..... that setup sounds noticeably better than the other 2 .
Make sure to set it to FLOORSTANDING speakers.
Enjoy , let us know your impressions...
BkPS Audio S300 , WiiM Ultra , Yamaha wxc-50 , Salk SuperCharged Songtowers , Kimber Kable 4TC, Sony 48” - BEDROOM
B&K EX-442 ( it will go in my casket when I die ... ) , PS Audio 4.6 preamp ( old school , but it still jams on ... ) , Eversolo DMP-A6 , Boston Acoustic voyager 7’s - POOL
Parasound A21, Eversolo DMP-A8 , Kimber Kable 4vs , Ascend Acoustics ELX Ribbon Towers , Sony XBR-A8F 65” OLED - DEN , MAIN system
Onkyo TX-nr609 , Polk atrium 7 , Boston acoustic sound ware (4) , Boston acoustic sub , B&W center , Sony 65” TV - PATIO -
Out of the box.... Sounds good.
Parasound HCA 750A driving a pair of Lsi7. Streaming Spotify over Bluetooth for now. -
You copy me, internal dac isn't terrible for sure- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
Groovy! Didn't know you had one.
It's good stuff, the mconnect app does mqa for tidal and it works for quobuz
I find using wired versus wireless makes a difference- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
I read that in Short Round's voice, and added a Docta Jones after copy meYou copy me, internal dac isn't terrible for sureI disabled signatures. -
I do believe that this is the longest review Russ has ever done. Bravo man.Out of the box.... Sounds good.
Thanks. Buy one -
Wxc50 does now than Bluetooth, it's a very capable streamer- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
Settle down foo! WiFi coming up soon.
Yamaha makes trash.afterburnt wrote: »They didn't speak a word of English, they were from South Carolina.
Village Idiot of Club Polk -
Why is the room tilted like that?My New Year's resolution is 3840 × 2160
Garage | Polk Monitor 5B's
Closet Yamaha M80 | 2 Polk MP3K subs| Yaqin MC100B with Shuguang Treasures KT 88's & CV181Z's | Tesla E83CC's | Marantz 2252B | Marantz 2385 |Polk SDA SRS 2.3 | LSiM 705's | -
I was just kidding. I'm a big fan. How's the new house?afterburnt wrote: »They didn't speak a word of English, they were from South Carolina.
I know. All good here. Getting settled in and getting back to a normal life.
Mikey081057 wrote: »
Old house or I'm drunk. Not sure. -
Perhaps both?My New Year's resolution is 3840 × 2160
How would this compare to the Node2 or 2i?
Yamaha makes trash.
Good thing I know this is just banter.
DSC_0241 by Mark Hardy, on Flickr
My little friends have very sensitive egos.
I considered the node ...
I went with the Yamaha ..... 3 of them .....
Closest thing I could find that did everything the Yamaha did was the maranta NA 6006 - at twice the price - and no 12v trigger ....
Way more flexible , Tons of inputs and digital outputs so you can use as a transport with an external DAC , internal power supply , and biggest reason for me is it has SiriusXM- which I listen to a lot ....
It’ll do SiriusXM In 16/44.1 - sounds pretty good.
Although the node will do TIDAL MQA , I feel it’s not that important to me - especially since I’m using an 851n for my main critical listening rig for Tidal and fed SiriusXM via coax from the Yamaha ....
It really is a huge bang for the buck ...
BKHow would this compare to the Node2 or 2i?
