Looking for a pair of bookies for my son's gaming system
DaveHo
Specifically, a pair of Athena AS-B1 speakers or their larger siblings, the AS-B2. Anybody have a pair tucked away? I found the matching center local & purchased the AS-B1 bookies on eBay only to have them arrived damaged because of piss poor packing.
Conversely, a pair of bookies & matching center of a different brand would work. The trick is going to be keeping it cheap. If things had worked with the Athenas I'd have been into them for a shade under $120 for all 3. I'd go more than that for the right matching LCR, but $200 is the max.
Watcha got?
Watcha got?
Dave - I may have something that could work. And, I'll be in Harrisburg in two weeks, so a bit closer to you. I have a pair of Polk RT35i bookies that are pretty beefy. They're not perfect (think the vinyl is peeling a little around the baffle, but not too bad). I also have a small center (I think it's the CS245i. However, I think there is an issue with one of the drivers in it. I think it may be replaced. I got these to use for outdoor movie night, and IIRC, the center was crackling here and there.
You can have them if you think they'll work. Consider it a karma for the holidays as another thanks for the generosity given to my in my WTB post for a CD changer.
I'll double check tonight and get some pictures if you're interested. -
Watcha got?
We have a pair of the AS-C1, the Center speaker with 2 woofers and tweeter between them.
Used them as a stereo pair, sound similar to the AS-B1, but with 2 woofers, a bit less deep bass, but more clarity.
Shipping might be steep, they are somewhat heavy though.
FYI the AS-B1 is the earlier version, AS-B2 the later inferior small bookshelf version (thinner cabinet, and cheaper tweeter that looks identical from the front)
We have owned a few of both versions. The later uses like 1/2" Mdf, and the earlier close to 3/4"....you can hear the difference if you rap on them.
"B" stands for Bookshelf, and the B1 B2 signifies what version.
"C" stands for Center and the 1 and 2 which version...early or later. -
Wow, very generous of you! Those would be perfect. Let's see if we can workout the meeting logistics. Sending PM.
Karma! Love it! Well done @scubalab !Basement: Polk SDA SRS 1.2tl's, Cary SLP-05 Pre with ultimate upgrade,McIntosh MCD301 CD/SACD player, Northstar Designs Excelsio DAC, Cambridge 851N streamer, McIntosh MC300 Amp, Silnote Morpheus Ref2, Series2 Digital Cables, Silnote Morpheus Ref2 Series2 XLR's, Furman 15PFi Power Conditioner, Pangea Power Cables, MIT Shotgun S3 IC's, MIT Shotgun S1 Bi-Wire speaker cables
