SDA 1 pin style interconnect cable wanted
Many years ago I bought a pair of SDA 1 speakers from a friend. Unfortunately he had lost the interconnect cable. I have the pin style connectors. Does anyone have a cable they would like to sell or instructions on how I can build my own.
Answers
  • vmaxer
    vmaxer Posts: 5,120
    That looks odd to me. Is it the original connector?
    Pio Elete Pro 520
    Panamax 5400-EX
    Sunfire TGP 5
    PS Audio GCPH phono pre
    Sunfire CG 200 X 5
    Sunfire CG Sig 405 X 5
    OPPO BDP-83 SE
    Ctr CS1000p
    Sur - FX1000 x 4
    SUB - SVS PB2-Plus
    Workkout room:
    Onkyo TX-DS898
    GFA 555
    Yamaha DVD-S1800BL/SACD
    Ft - SDA 1C
    Not being used:
    RTi 38's -4
    RT55i's - 2
    LSI 15's
    CSi40
    PSW 404
  • yes... its original.
  • vmaxer
    vmaxer Posts: 5,120
    Ok, @F1nut can you help??
    Pio Elete Pro 520
    Panamax 5400-EX
    Sunfire TGP 5
    Sunfire CG 200 X 5
    OPPO BDP-83 SE
    Ctr CS1000p
    Sur - FX1000 x 4
    SUB - SVS PB2-Plus
    Workkout room:
    Onkyo TX-DS898
    GFA 555
    Ft - SDA 1C
    Not being used:
    RTi 38's -4
    RT55i's - 2
    LSI 15's
    CSi40
    PSW 404
  • vmaxer
    vmaxer Posts: 5,120
    jtomasino wrote: »
    Usually they have 2 blades or 1 pin and 1 blade.
    Pio Elete Pro 520
    Panamax 5400-EX
    Sunfire TGP 5
    Sunfire CG 200 X 5
    OPPO BDP-83 SE
    Ctr CS1000p
    Sur - FX1000 x 4
    SUB - SVS PB2-Plus
    Workkout room:
    Onkyo TX-DS898
    GFA 555
    Ft - SDA 1C
    Not being used:
    RTi 38's -4
    RT55i's - 2
    LSI 15's
    CSi40
    PSW 404
  • All I can say is both speakers have this type of connector and my friend had purchased the speaker new.
  • vmaxer
    vmaxer Posts: 5,120
    jtomasino wrote: »
    Can you take another photo from further back showing more of the speaker?
    Pio Elete Pro 520
    Panamax 5400-EX
    Sunfire TGP 5
    Sunfire CG 200 X 5
    OPPO BDP-83 SE
    Ctr CS1000p
    Sur - FX1000 x 4
    SUB - SVS PB2-Plus
    Workkout room:
    Onkyo TX-DS898
    GFA 555
    Ft - SDA 1C
    Not being used:
    RTi 38's -4
    RT55i's - 2
    LSI 15's
    CSi40
    PSW 404
  • Did the 2 pictures get posted.
  • vmaxer
    vmaxer Posts: 5,120
    jtomasino wrote: »
    I only see 1
    Pio Elete Pro 520
    Panamax 5400-EX
    Sunfire TGP 5
    Sunfire CG 200 X 5
    OPPO BDP-83 SE
    Ctr CS1000p
    Sur - FX1000 x 4
    SUB - SVS PB2-Plus
    Workkout room:
    Onkyo TX-DS898
    GFA 555
    Ft - SDA 1C
    Not being used:
    RTi 38's -4
    RT55i's - 2
    LSI 15's
    CSi40
    PSW 404
    pitdogg2 Posts: 27,055
    edited December 2019
    jtomasino wrote: »
    Correct first SDA used a same input as the RTA12. The RTA 12 used it to connect top section to lower.
    Very slim to none odds to getting an original cable. I'd start looking at the speakon connection we SDA folks have been using.
    vmaxer wrote: »
    jtomasino wrote: »
    It's original SDA1 with front port holes.
  • Ok... thx for all the responses. I will look into the speakon connectors as you suggested.
  • vmaxer
    vmaxer Posts: 5,120
    vmaxer wrote: »
    jtomasino wrote: »
    I have never seen them before.
    Pio Elete Pro 520
    Panamax 5400-EX
    Sunfire TGP 5
    Sunfire CG 200 X 5
    OPPO BDP-83 SE
    Ctr CS1000p
    Sur - FX1000 x 4
    SUB - SVS PB2-Plus
    Workkout room:
    Onkyo TX-DS898
    GFA 555
    Ft - SDA 1C
    Not being used:
    RTi 38's -4
    RT55i's - 2
    LSI 15's
    CSi40
    PSW 404
  • These speakers may be from their original or very early days. They still sound great but want all drivers working.
    jtomasino wrote: »
    https://www.neutrik.com/en/product/nl4fx
    https://www.neutrik.com/en/product/nl4mp-uc
  • dkfreebird
    dkfreebird Posts: 1,186
    Be very careful wiring that cable if you make one. If I remember right the wires don't go like the other pin/blade cables. I think they switch in the cable itself instead of inside the cabinet. I almost lost a Adcom 555 wiring it wrong.
    Polk 1.2tl's Modded with dreadnought
    Musical Fidelity M6Si
    North Star Intenso Dac
    Auralic Aries Mini Streamer
    Oppo 103
    Pangea PC
    Wireworld Equinox 7 interconnects
    Wireworld Equinox 7 Speaker Cables and Jumpers
    Backups 2.3tl, Crs+ pin/blade with stands.Monitor 5 peerless,Polk R200,McCormack Dna 0.5 Deluxe McCormack Dna 1,Dared Sl 2000A,Dayens Ampino,Rogue Magnum 66 pre
    Wire it just like the cabinet wiring. the wiring DOES switch pins inside cabinet. MAKE the cable positive to positive and negative to negative and do the switch at the speaker end. TAKE PICTURES of the wire placement BEFORE YOU EVER TAKE ANYTHING APART.
    F1nut Posts: 51,783
    vmaxer wrote: »
    You rang?
  • nanook52
    nanook52 Posts: 4
    pitdogg2, thanks for your input on this (I have the same very early SDA 1 and would also like to connect them), but I did not quite understand your wiring instructions. Are you saying that the left pin on the left speaker interconnect does or does not have continuity with the left pin on the right speaker interconnect?
    Open it up and look. If the large blade on the speaker end is white the small blade on the right speaker should be white
  • nanook52
    nanook52 Posts: 4
    Thanks pitdogg2, it is about time that I took a peak inside the cabinets. I had been on this track (https://forum.polkaudio.com/discussion/63792/questions-about-sda-1-speakers) and found seemingly compatible plugs and connectors, but they also left the polarity issue unresolved and I didn't know which route to pursue.
    edited March 2020
    Open it up and look. If the large blade on the left speaker end is white wire the small blade on the right speaker should be white wire
    Fixed it
    I would think the pins are wired the same. I've never dealt with them.
    Now wires of course could be a different color than white but hopefully you understand.
  • nanook52
    nanook52 Posts: 4
    The nice folks at Polk support said that I just need a basic 3 pin XLR cable (1 of the pins is not needed) to connect these first generation (pin/pin) SDA 1 speakers. Thus, I ordered a Male-Female XLR cable and an adapter plug that has 2 female ends. Hopefully this will be $20 well spent and I can finally experience what SDA is all about. I hope to post results when the cable and adapter arrive.
    F1nut Posts: 51,783
    Neutrik SpeakOn connectors would have cost even less and are vastly superior in every way.
  • nanook52
    nanook52 Posts: 4
    Thank you F1nut, I appreciate the feedback. I will look into the SpeakOn connectors for round 2 of my exploration into getting everything I can out of these great speakers. Hopefully the XLR cable will provide a first taste of the SDA and I will go from there.
  • timkrik
    timkrik Posts: 1
    edited August 2022
    @nanook52 , i recognize this post is 2+ years old now.
    Did an XLR or SpeakOn cable resolve the issue for you?
    I am looking at the pair of Polk SDA 1 speakers having the same interconnect cable jacks (2 pin) as pictured at the beginning of this post. As is common, the cable is missing at this time.
    Cheers.
    F1nut Posts: 51,783
    Air tight SpeakOn sockets work beautifully.
