Tubes on the polk forum!
madmax
madmax Posts: 12,434
edited May 2002 in Electronics
I saw tubes listed on the description of this section!!! Who has tubes? Lets get a list going. Bottleheads???
I'm here,
madmax
Vinyl, the final frontier...
Post edited by madmax on
  • -justin-
    -justin- Posts: 891
    edited April 2002
    I have a fender custom amplifier with TUBES! I love the red glow when the lights are out.
    ~JB
  • madmax
    edited April 2002
    I forgot to list my tube equipment, Duh, that was the essence of the post.
    Stereo equipment:
    Luxman CD player with 12AX7 pre-amp out tubes.
    Two Jolida 302A integrated amps. (left and right)
    Guitar/keyboard equipment:
    Marshall JCM900 guitar head
    Bluetube preamp
    Marshall tube microphone
  • hatchm
    hatchm Posts: 28
    edited April 2002
    HT/Family Room:
    Denon 2801 Reciever
    Polk 5jr mains
    Polk CS245i center
    Polk R10 surrounds
    Cheap sub I'm building from a Madisound 1252DVC
    Sony DVD
    Sony 5 disk ES series changer
    Panasonic S-VHS VCR
    XBox
    Toshiba 32" TV (trying to talk my wife into HD Proj)
    Living Room (mainly used for The Wiggles & Disney channel):
    Old Sony receiver from college (mid-80's)
    Cheap Apex DVD changer
    Panasonic S-VHS VCR
    Toshiba 20" TV
    Bose 141 (only used for background music, my wife likes SMALL speakers)
    Relegated to the garage until I get a den/media room (and the kids are old enough not to break them):
    Bottlehead Foreplay (stock, just built)
    Angela/JEL SE 2A3 (being built)
    Tons of Radio Shack full-rangers (incl 1354 & Fostex 103) waiting to be put into some wood once I get the 2A3 built.
    Zenith PP EL84 console I need to recondition.
    Zenith 7695 integrated I'm going to recondition and put in a nice cabinet for my brother.
    Lots of projects, too little time. Looking forward to hearing what others have though.
    Hatch
    Everett, WA
  • gidrah
    gidrah Posts: 3,049
    edited April 2002
    Currently there's the GoldStar microwave and a few CRT loaded televisions, but I've got my eye out for a good deal on an audio amp or preamp.
    Make it Funky! :)
  • tonyv1
    tonyv1 Posts: 365
    edited April 2002
    My stereo rig:
    Magnepan MG12
    Parasound HCA 1500A Amp
    Anthem PRE 2L Special Edition TUBE Preamp
    Rotel RCD 951 CDP
    MSB Link III DAC
    Harmonic Technology Pro-Silway MkII interconnects
    XLO Ultra 6 speaker cables
    Love the way the tube preamp smoothes out the sound.
    Would love to drive the Maggies with a set of Sonic Frontiers Power 2 or 3 Tube amps.
    HT rig:
    Polk Audio
    RT 16, CS275, RT35 and PSW 120
    Denon AVR-2700 receiver
    Panasonic DVD
    Sharp VCR
    JVC 32D501 TV
    Monster Cable Z2 speaker cables to the RT16
    Home Depot 12 AWG everywhere else
  • Aaron
    Aaron Posts: 1,853
    edited May 2002
    How do you like your MSB Link DAC?
    Aaron
  • tonyv1
    tonyv1 Posts: 365
    edited May 2002
    I love it. Noticed cleaner imaging and details. I was like listening to new CDs again. The Rotel has HDCD on and I don't even use that anymore. I have it wired so that I can switch between the CDP and DAC at the preamp. The next step is to get the 24/96 upsampling board (which will do 24/132).
  • jeberhart
    jeberhart Posts: 69
    edited May 2002
    No tubes in my home theater setup, but in the music room I have two guitar amps that qualify: A Tube Driver hybrid that has a clean transistor channel and a distortion tube channel, and you can combine the two if you want. Also, an ancient Fender Super Reverb tube amp, but can't use it right now because something is wrong; gotta get it repaired. Last time I tried to play through it, it about shocked the daylights out of me.
  • madmax
    edited May 2002
    Probably about 400 volts! Be careful with that monster.
  • jrausch
    jrausch Posts: 510
    edited May 2002
    Polk Audio and tube amps don't mix very well. I'm sure somewhere out there someone is using that combination. Tubes smooth out the music because there is no switching involved in the power source. Polk speakers (The good ones) are smooth by themselves. 2 smoothes make for an overly smooth system. I listened to a pair of SDA 2.3tl's on a McIntosh tube amp and was floored at just how crappy they sounded. No crisp/smooth highs and the bass was muddy and washed out. The SDA imaging was non-existent. The Klipsch Forte's they ran behind the Polk's sounded great though. I'm sure Dean can attest to that.
    "The only way to get rid of a temptation is to yield to it."
  • madmax
    edited May 2002
    That is definately not the case with the Jolida 302A! Nothing is smoother and the sda effect is ever so slightly enhanced. Keep in mind that there are many tube designs out there. I have tried no other than the Jolida so I believe some will not perform well. Soupbone had a problem with the SDA function with the particular type of tube amp he was using as well. The list of reasons why a particular tube amp may not perform well is scary but if you luck into the right combination you will be in heaven!!!
    Why some do not work well:
    1: Output transformer is offers too high of a resistance between +/- terminals...loss of SDA effect.
    2:Ground potential different between channels...loss of SDA effect, bias goes dangerously high.
    3:Output impedance of the amp must be held closely...A resistor less than 200 ohms may have to be placed across the output terminals or the bias runs dangerously high. (older SDA's)
    4:Tube combinations make all the difference...the chineese tubes my amp came with had less than reasonable bass response but changing to some of the more reasonable ones provided everything my Sunfire amp had.
    madmax
