multiple system hook up
is there any way to hook up 2 different systems to work together?? a Polk signa S2 with a Samsung 5.1 surround sound system
both systems have a sub woofer
  • FestYboy
    FestYboy Posts: 3,861
    What are you actually trying to accomplish? Need more details before useful advise is given.
  • afterburnt
    afterburnt Posts: 7,892
    Just a WAG but optical to the bar and HDMI to the 5.1?
    tonyb Posts: 32,906
    FestYboy wrote: »
    Bad sound....by my observations from the cheap seats. :)
    F1nut Posts: 49,792
    I'm sitting next to Tony.
  • afterburnt
    afterburnt wrote: »
    I didn't read your post correctly, I thought you meant to use one or the other. Why would you want to use both at the same time?
