Ethernet network hub rules?
So why are you adding it? lol
Because I am buying an Olive music server with wireless network access, and they have a free iPad app for managing music on the server.
While I could go with a wired connection to the music server I prefer to eliminate any possible electrical interference from a CAT5 or CAT6 cable to the interconnects and speaker wire. I am assuming the wireless will not create audible interference. And, the iPad is wireless.Lumin X1 file player, Westminster Labs interconnect cable
Three 20 amp circuits. -
Serendipity wrote: »If you have a wired router, and say 2-3 wireless routers (one on each floor), all you have to do is turn the Wireless Routers into Access Points and then run an ethernet cable to each unit.
Then you have a Wireless Network on every floor!
I have wireless on all 3 floors, outside, in the street with a single cisco aironet 1100 WAP. Would it do me any good to enable the radios on my linksys running dd-wrt in the basement? I always prefer wire over wireless but i plan on getting a android tablet when they release. -
Youll have to let us know how it turns out.. I guess it depeneds on the funtionality of the app alot. -
Did you ever get this figured out?
I noticed that some routers don't like being demoted to switches or access points - so I wouldn't recommend using a router as a switch if you don't have to.polkaudio RT35 Bookshelves
polkaudio 255c-RT Inwalls
polkaudio DSWPro550WI
polkaudio XRT12 XM Tuner
polkaudio RM6750 5.1
Thanks for asking. I ended up redoing my "IP Closet" where I redid all cables to be on the 192.168.0.1 router adding a 5 port switch. I turned off DHCP in the dsl modem router, setting the 192.168.0.1 router as a fixed address 192.168.1.3 // 255.255.255.0 sub // 192.168.1.254 gateway // DNS set as 192.168.1.254. I also set the HTPC as a fixed address (a tip of a co-worker) which stated network speed works faster if set as fixed over dhcp setting.
The goal here was to use a 1000 router / network in house, where the dsl modem / router is the feed it.
Speakers
Carver Amazing Fronts
CS400i Center
RT800i's Rears
Sub Paradigm Servo 15
Electronics
Conrad Johnson PV-5 pre-amp
Parasound Halo A23
Pioneer 84TXSi AVR
Pioneer 79Avi DVD
Sony CX400 CD changer
Panasonic 42-PX60U Plasma
WMC Win7 32bit HD DVR -
Congrats!
Just as an experiment, I connected two Netgear Routers together by plugging one unit's WAN port into the other's "1-4" LAN ports. Thus creating a double-router chain with both routers' DHCP turned on.
What happened was that the connection would time out every so often and require resetting of the 2nd Router in order for connectivity to be restored. And if they were both connected via the LAN ports, NOTHING would work as they would be both trying to assign DHCP IP addresses all the time.
So the *best* solution, which you have used, is to turn off DHCP on the dsl modem router and use your Netgear (which BTW is a nice unit) as the DHCP server. Everything should work fine with this configuration.polkaudio RT35 Bookshelves
Serendipity wrote: »Congrats!
>> Did you changed the second Routers address to a different third octet of the first feed Router? I never had an issue doing it this way.<<So the *best* solution, which you have used, is to turn off DHCP on the dsl modem router and use your Netgear (which BTW is a nice unit) as the DHCP server. Everything should work fine with this configuration.
Thanks running fine.
Speakers
CS400i Center
RT800i's Rears
Electronics
Parasound Halo A23
Pioneer 84TXSi AVR
Pioneer 79Avi DVD
disneyjoe7 wrote: »Thanks for asking. I ended up redoing my "IP Closet" where I redid all cables to be on the 192.168.0.1 router adding a 5 port switch. I turned off DHCP in the dsl modem router, setting the 192.168.0.1 router as a fixed address 192.168.1.3 // 255.255.255.0 sub // 192.168.1.254 gateway // DNS set as 192.168.1.254. I also set the HTPC as a fixed address (a tip of a co-worker) which stated network speed works faster if set as fixed over dhcp setting.
Are you running NAT on both the dsl modem and the netgear router? -
NAT is something which I don't play with, so I'm thinking default settings. I checked the dsl Router and it stated ON, the wireless / main Router I'm not sure but seen something like NAT filter ON.
Speakers
CS400i Center
RT800i's Rears
Electronics
Parasound Halo A23
Pioneer 84TXSi AVR
Pioneer 79Avi DVD
Yes, I like the router as it seems to everything I need... But can I change the wireless power output? The issue I have is I must have a lot of refection of signal so I have a weak signal. With a Linksys router I found that 41mw worked best in my house and would have a 80% signal, right now I at 31% signal.
Speakers
CS400i Center
RT800i's Rears
Electronics
Parasound Halo A23
Pioneer 84TXSi AVR
Pioneer 79Avi DVD
disneyjoe7 wrote: »Yes, I like the router as it seems to everything I need... But can I change the wireless power output? The issue I have is I must have a lot of refection of signal so I have a weak signal. With a Linksys router I found that 41mw worked best in my house and would have a 80% signal, right now I at 31% signal.
I wouldn't recommend it. Even if you had an open-source router (like the Netgear RP614L), which allows you to run DD-WRT, setting the router to a higher power output would greatly shorten its life.
Instead, why don't you pick up a few access points (or use your old router as an access point) to expand your coverage?polkaudio RT35 Bookshelves
I wouldn't upgrade the transmit radio for a better signal, but I felt a reduce transmit radio would work better. DD-WRT wrt54g router had a 71mw output but when I did a 41mw output my signal got better. I like your idea to use the router to expand the network. Or my idea to use the wrt54g router to do 54g network only, but then I wonder about my network printer again which would be on another optet number.
Speakers
CS400i Center
RT800i's Rears
Electronics
Parasound Halo A23
Pioneer 84TXSi AVR
Pioneer 79Avi DVD
You should be fine. Use the wrt54g router as an Access Point only - you will still be able to print to your network printer.polkaudio RT35 Bookshelves
Roshalshas reported. BubyeLiving Room 2.2: Usher BE-718 "tiny dancers"; Dual DIY Dayton audio RSS210HF-4 Subs with Dayton SPA-250 amps; Arcam SA30; Musical Fidelity A308; Sony UBP-x1000es
Bedroom 2.1 Harmon Kardon HK3490; Bluesounds Node N130; Polk RT25i; ACI Titan Subwoofer
