7.2 Surround System
simoes
Just looking for some feedback on which speakers to add and complete my 7.2 system:
Currently have:
1 x CS10
2 x Monitor 70 series II - sides
2 x Monitor 60 series II - rears
2 x PSW125 subs
Looking to upgrade my CS10 but finding a decent CS2 series II/CS20 is impossible. I'm concerned about timbre matting so I think I'll upgrade all three fronts and move the 70s to the side. I'm thinking about 2 x RTIA7 and a CSI A6 as fronts. Are the A7s a serious upgrade to the 70s?
Currently have:
1 x CS10
2 x PSW125 subs
Projector - Optoma CinemaX P1 | Screen - Elunevision 120" Aurora 8k Ultra Short Throw NanoEdge
Media - HTPC: 120 TB Movies, Nvidia Shield | AVR - Denon AVR-X3700H | Amp - Outlaw 5000, Outlaw 2200 x 3, Outlaw 2220 x 2
Front Spkrs - Polk Audio RTiA9 | Center Spkr - Polk Audio CSiA6 | Surround Spkrs - Polk Audio RTiA7
Rear Spkrs - Polk Audio RTiA5 | Atmos - Polk Audio RTiA1 | Sub - HSU VTF-15H MK2 x 2
Answers
Short answer is yes....but I'd also upgrade those subs as well, maybe one much better one than 2 so-so ones.HT SYSTEM-
lsi 9's -
Tonyb: you took the words from my mouth! I was thinking, depending upon your (Simoes) space to fill, two much better subs first. Then your LCR.Short answer is yes....but I'd also upgrade those subs as well, maybe one much better one than 2 so-so ones.
Merry Christmas! Tony
*all connected w/Premiere ICs
4 dedicated 20A feeds; APC H15; 5 Furman Miniport 20s -
what sub should I get?Projector - Optoma CinemaX P1 | Screen - Elunevision 120" Aurora 8k Ultra Short Throw NanoEdge
Rear Spkrs - Polk Audio RTiA5 | Atmos - Polk Audio RTiA1 | Sub - HSU VTF-15H MK2 x 2 -
I think I made recommendations in your other thread, but below a grand this is hard to beat: http://www.hsuresearch.com/products/vtf-15hmk2.htmlLiving Room 2.2: Usher BE-718 "tiny dancers"; Dual DIY Dayton audio RSS210HF-4 Subs with Dayton SPA-250 amps; Arcam SA30; Musical Fidelity A308; Sony UBP-x1000es
that's a serious sub!Projector - Optoma CinemaX P1 | Screen - Elunevision 120" Aurora 8k Ultra Short Throw NanoEdge
SVS subs would be another option to consider.
Yep!! Give us a budget and we’ll help you spend it and then some!Living Room 2.2: Usher BE-718 "tiny dancers"; Dual DIY Dayton audio RSS210HF-4 Subs with Dayton SPA-250 amps; Arcam SA30; Musical Fidelity A308; Sony UBP-x1000es
