Apple cider vinegar
I've been drinking some of this to see if it is effective for acid reflux. It has helped me a lot.
My sister's doctor wants her to double her meds for her GERD, she's going to try the acv first. Apparently there are other benefits too from acv.....Any others using this?
Yep, my name really is Bob.
    mhardy6647 Posts: 34,921
    edited December 2019
    I don't understand how drinking something acidic is supposed to help with reflux -- is it like using exposives to put out oil well fires? :(
    I know this is a fad thing... but I do wonder how much if any actual objective study has been done on this? A quick googlage turns up stuff like this, which is about what I'd expect.
    https://www.medicalnewstoday.com/articles/324034.php#does-apple-cider-vinegar-soothe-acid-reflux
    https://www.healthline.com/health/digestive-health/apple-cider-vinegar-for-acid-reflux#treatment
    In other words, it probably won't do any harm; it may or may not do any good... and there will be folks for whom it would be contraindicated.
    So, to answer your question -- no (not using it)... but also no problem (so far, touch wood, as they say in the UK) with acid reflux.
    Oh, I will add one other thought (being of that old-school school of thought that says Western medicine has done a pretty good job over the past 600 years or so of 'evidence-based treatment') -- has your wife asked her doctor (or another doctor, if she's skeptical of hers) about the relative merits of drinking apple cider vinegar (with, presumably, the mother present) vs. good-ol' better-living-through-pharmacology solutions to GERD? Might be an interesting conversation to have.
    EDIT: By the way, anecdotal evidence doesn't mean unreal! :) There are plenty of real-world 'anecdotal' observations that are perfectly real and true, but that don't lend themselves to be applied to a broader segment of a population. I worked for a biotech company early in my career which did small, early-stage clinical trials of a drug that absolutely led to remarkable clinical remission of end-stage cancer of a particular type (NHL) in a few patients who had relapsed and showed no response to conventional therapies at the time. The problem was that extensive, statistically-powered clinical studies to prove the effectiveness of the drug failed. That doesn't mean the anecdotal results weren't real... but they weren't reproducible, either. The latter is enough to keep a drug from being approvable (and for good reason).
  • Emlyn
    Emlyn Posts: 4,623
    I tried it years ago to help treat reflux that was making asthma worse. Didn't do me any good with reflux or for anything else. Stomach acid is plenty strong enough all by itself. Also tried antacids. No benefit. Best thing for me was to just not eat anything a couple hours before bedtime and get some exercise. Also, watch out for the teeth. Acidic drinks are not good anyway, but vinegar is harsher still so rinse out the mouth after drinking.
    I have heard many people say it works for them though.
  • kevhed72
    kevhed72 Posts: 5,126
    It is good for cleaning cast iron pans!
    gudnoyez Posts: 8,156
    It does help but not the cheap apple cider you need to get the one that contains the Mother. I have a friend that swears by it to help him with his gert. Some praise its benefits others dont.
  • GlennDog
    GlennDog Posts: 3,149
    I’ve heard ACV is pretty abrasive on the enamel of your teeth
    Pre Cary SLP-05
    Power Rogue M180 Dark monos
    Mains Salk HT2-TL
    Rythmik F12
    pitdogg2 Posts: 26,936
    GlennDog wrote: »
    Dude it's not mouth wash ;)
  • motorhead43026
    motorhead43026 Posts: 4,001
    Make sure to dilute it well as it will erode your esophagus over time. To help keep from damaging your teeth drink it through a straw and rinse.
    And yes Bragg is the good stuff.
    – Kevin Alfred Strom
  • GlennDog wrote: »
    Yes, you are absolutely right. It will etch the enamel. Trust me on this...I just retired from spending 43 years fixing broken smiles!
    McIntosh MA252 Integrated Amp, LUMIN D2 Network Music Player, Yamaha Aventage RX-A840 receiver, Emotiva XPA Gen3 2 channel amp, Polk LSiM 703 speakers. Oppo UDP-203 Blu-Ray player, Polk LSiM 705 speakers. Polk Signature S20 speakers.
  • CH46E
    CH46E Posts: 3,595
    gudnoyez wrote: »
    I use this brand. $$$ but supposed to be worth it.
  • muncybob
    muncybob Posts: 3,233
    kevhed72 wrote: »
    Would it not erode the "seasoning"?
    I also do not understand how something acidic helps with reflux/heartburn but, so far it works for me if I have any symptoms early in the day. Does not seem to be as effective if taken late at night though...that's the time for omeprazole for me.
    It is the bacteria that the mother provides to neutralize the acid build up in your gut.
    I just took my mornings dose of Bragg's got to keep my complexion and good looks in check. Seriously Braggs is the brand to get.
  • muncybob
    Braggs is what we have although there was another brand there with the mother also. Wife is stopping with it though, it burns her throat.
    tonyb Posts: 33,066
    gudnoyez wrote: »
    Yep. Usually your not suppose to take more than a tablespoon or 2 a day, and mixed with water or tea is best. Drinking it straight can burn your throat a bit. You have to dilute it, cut it, with another liquid or it can get nasty.
    Just try a teaspoon in 4 oz. water and chug it, once in the morning and once before bed. You may notice a difference quickly, if not, then don't use it, simple eh ?
