PSA Windom Update
Not yet. I'm staying at my dads house while the will will is being executed, so, I just brought an integrated and am using blutooth to stream to the old April Stello DAC...simple and portable.
Gotcha. Definitely more important things at the moment, so I'll stop bugging you!
You'll have something to look forward to when you return home.
➀Speakers: Polk1.2tl's (Uber Mods) ➁Pre/Amp/DAC: PS Audio BHK Signature & 250, DirectStream ➂Cables/IC's: MIT S1Bi-Wire/S1 Balanced +Avel Lindberg 1000VA "Dreadnought" ➃Power Conditioner: PS Audio P15 Power Plant ➄Power Cords: Core Power Technologies Gold, DH Labs Power Plus DIY w/Neotech NC-P301 & P311ends ➅Streaming: Roon ROCK on wifi'd NUC, TP-Link WAP, & Uptone EtherREGEN, AfterDark, Emperor Double Crown Clock, Black Modernize LPS, PS Audio AirLens⟿Ω☯☥☮⟿🔊♩♪♫♬♩♪♫♬♩♪♫♬ -
@JayCee loading Huron and then to Wisdom worked. Seems to have a bit more sparkel on top as well as more depth and clarity.
The update process is easy but maybe there is something with snowmass that doesn't like Wisdom update? No idea. All i know is it worked and i like the improvement.Klipsch The Nines, Audioquest Thunderbird Interconnect, Innuos Zen MK3 W4S recovery, Revolution Audio Labs USB & Ethernet, Border Patrol SE-I, Audioquest Niagara 5000 & Thunder, Cullen Crossover II PC's. -
@erniejade, glad to see you have it updated. Earlier in the week I loaded a previous firmware for comparison to Windom and had a "bad" load going back to Windom. Listened for a bit and it clearly sounded off vs. what I'd heard the past few weeks. Top end was grating for extended listening and soundstage wonky. On my BHK pre anything above 25 severely emphasised the bad. Took my own advice and loaded way back to Pike's Peak, removed the SD card and rebooted twice, consecutively, before it came back. Have decided to leave well enough alone and remain on Windom.Seems to have a bit more sparkel on top as well as more depth and clarity.
Change in highs aren't that dramatic on my system but noticed the same with respect to clarity. Really easy to hear lyrics and smaller audio cues. Another improvement is off center instrument and performer location. They're really locked in w/respect to soundstage position. Had a jazz listening session and saxaphones sound sweet.
Major breakthrough for SACD DSD rips...now sound 100% better than previous firmware. As I previously stated, I'd kind of written them off. Always appeared overly soft and not as dynamic as I know they should. Standard FLAC rips from the same SACD's gave me more enjoyment. Now, DSD is king and is better than ever.
Thanks for the advice here guys. I tried to update 3 or 4 weeks ago after seeing this thread but never was successful. Finally had a chance to revisit last night.
Nothing worked until I first reverted to Huron. (I also removed blank spaces from the usb stick name as suggested somewhere, but I don't know if that had any effect.) After that, I was able to update to Windom. The reversion to Huron seems to be a recurring theme in the PSA troubleshooting threads; so if anyone is still having problems, be sure to give this a try.
It's been a while since I've been able to listen to this rig, but the sound seems a bit more lush with added depth. I'm pleased.
Thanks again!
CraigBeach Audio: Rega RP6 (mods) - AT33PTG/II - Parks Budgie SUT - PSAudio NPC * Eversolo DMP-A6 * Topping D90iii * Joule-Electra LA-100 mkIII * Pass Aleph 30 * MIT S3 * Polk SRS 2.3tl (mods) * PSAudio PPP3
Town Porch: WiiM Pro Plus * Sunfire Sig II * Canare 4S11 * Magnepan 1.6 * Dectet -
Hi Craig (@vcwatkins). Good to see you have it updated. The bouncing around between firmware to get this load to take has been frustrating for many. Hopefully, since Ted, Paul & crew acknowledge the problem and it's getting quite a bit of chatter on the PSA site, they'll do something about it moving forward.It's been a while since I've been able to listen to this rig, but the sound seems a bit more lush with added depth. I'm pleased.➀Speakers: Polk1.2tl's (Uber Mods) ➁Pre/Amp/DAC: PS Audio BHK Signature & 250, DirectStream ➂Cables/IC's: MIT S1Bi-Wire/S1 Balanced +Avel Lindberg 1000VA "Dreadnought" ➃Power Conditioner: PS Audio P15 Power Plant ➄Power Cords: Core Power Technologies Gold, DH Labs Power Plus DIY w/Neotech NC-P301 & P311ends ➅Streaming: Roon ROCK on wifi'd NUC, TP-Link WAP, & Uptone EtherREGEN, AfterDark, Emperor Double Crown Clock, Black Modernize LPS, PS Audio AirLens⟿Ω☯☥☮⟿🔊♩♪♫♬♩♪♫♬♩♪♫♬
You're obviously a man of great taste, hehe. In gear AND music.Beach Audio: Rega RP6 (mods) - AT33PTG/II - Parks Budgie SUT - PSAudio NPC * Eversolo DMP-A6 * Topping D90iii * Joule-Electra LA-100 mkIII * Pass Aleph 30 * MIT S3 * Polk SRS 2.3tl (mods) * PSAudio PPP3
You're obviously a man of great taste, hehe. In gear AND music.➀Speakers: Polk1.2tl's (Uber Mods) ➁Pre/Amp/DAC: PS Audio BHK Signature & 250, DirectStream ➂Cables/IC's: MIT S1Bi-Wire/S1 Balanced +Avel Lindberg 1000VA "Dreadnought" ➃Power Conditioner: PS Audio P15 Power Plant ➄Power Cords: Core Power Technologies Gold, DH Labs Power Plus DIY w/Neotech NC-P301 & P311ends ➅Streaming: Roon ROCK on wifi'd NUC, TP-Link WAP, & Uptone EtherREGEN, AfterDark, Emperor Double Crown Clock, Black Modernize LPS, PS Audio AirLens⟿Ω☯☥☮⟿🔊♩♪♫♬♩♪♫♬♩♪♫♬
Completely forgot the XPA-2 was yours! Very much enjoyed my time with it.
And sorry for the derail, but here's Beck at a May festival.
Just updated my DS Jr to Windom ... Wow-at first blush the bass in my system is much more pronounced (nice and tight
More of a 3D affect as well ...while the sound stage is higher/deeper. The clarity and imaging has also improved from the Snowmass version. I'm pretty happy with the improvement.
Main Rig:
Antipodes DX > Roon > PS Audio Directstream Jr.>deHavilland Ultraverve 3 >Belles Reference 150a >Harbeth C7 ES3
Second Rig:
Roon> PS Audio Directstream Jr Bridge II > EE Minimax pre (Tutay mods) >Belles 150A Ref >Monitor 5 (Westmassguy-modded) -
I was so happy with the performance of Windom in the one DirectStream DAC that I own that I could not pass up PS Audio's "Friends & Family" offer for Black Friday: Brand spanking new DirectStream DAC WITH Bridge II installed for $3,999.00. That's over 40% off list.
I received the DAC today. I plan to install it as soon as the doctor clears me to lift >20 lbs. Unfortunately, it's not clear to me when that will be.Family Room, Innuos Statement streamer (Roon Core) with Morrow Audio USB cable to McIntosh MC 2700 pre with DC2 Digital Audio Module; AQ Sky XLRs to CAT 600.2 dualmono amp, Morrow Elite Speaker Cables to NOLA Baby Grand Reference Gold 3 speakers. Power source for all components: Silver Circle Audio Pure Power One with dedicated 20 amp circuit to main panel.
Exercise Room, Innuos Streamer via Cat 6 cable connection to PS Audio PerfectWave MkII DAC w/Bridge II, AQ King Cobra RCAs to Perreaux PMF3150 amp (fully restored and upgraded by Jeffrey Jackson, Precision Audio Labs), Supra Rondo 4x2.5 Speaker Cables to SDA 1Cs (Vr3 Mods Xovers and other mods.), Dreadnaught with Supra Rondo 4x2.5 interconnect cables by Vr3 Mods. Power for each component from dedicated 20 amp circuit to main panel, except Innuos Statement powered from Silver Circle Audio Pure Power One. -
Nice pickup. I never received an email on the sale!Klipsch The Nines, Audioquest Thunderbird Interconnect, Innuos Zen MK3 W4S recovery, Revolution Audio Labs USB & Ethernet, Border Patrol SE-I, Audioquest Niagara 5000 & Thunder, Cullen Crossover II PC's.
I don't know what their criteria were for sending out the notification of the sale, but I suspect it had to do with the number of registered PS Audio products owned. I went back to the special URL for this sale today, and it is no longer available. To gain access to the site required a password that was in the email notification.
I suppose this sort of stuff goes on all the time, but this was a first for me -- not of "Friends & Family" sales or the like, but of the requirement for a special password.Family Room, Innuos Statement streamer (Roon Core) with Morrow Audio USB cable to McIntosh MC 2700 pre with DC2 Digital Audio Module; AQ Sky XLRs to CAT 600.2 dualmono amp, Morrow Elite Speaker Cables to NOLA Baby Grand Reference Gold 3 speakers. Power source for all components: Silver Circle Audio Pure Power One with dedicated 20 amp circuit to main panel.
Wow, Phil (@Moose68Bash), dual Directstreams...just....WOW! I had a feeling you'd like Windom but didn't predict you'd buy a second machine. Replacing the PerfectWave, w/the DSD, in the workout system?
Like erniejade, I didn't get a F&F notice. I have 3 pieces registered w/PSA (BHK Pre/250/DSD). Did, however, receive the "Tiers of Cheer" promo but am not looking to purchase anything.
Wishing you clearance to bench press the DAC and the ensuing sweet sounds that'll make your workouts more enjoyable.➀Speakers: Polk1.2tl's (Uber Mods) ➁Pre/Amp/DAC: PS Audio BHK Signature & 250, DirectStream ➂Cables/IC's: MIT S1Bi-Wire/S1 Balanced +Avel Lindberg 1000VA "Dreadnought" ➃Power Conditioner: PS Audio P15 Power Plant ➄Power Cords: Core Power Technologies Gold, DH Labs Power Plus DIY w/Neotech NC-P301 & P311ends ➅Streaming: Roon ROCK on wifi'd NUC, TP-Link WAP, & Uptone EtherREGEN, AfterDark, Emperor Double Crown Clock, Black Modernize LPS, PS Audio AirLens⟿Ω☯☥☮⟿🔊♩♪♫♬♩♪♫♬♩♪♫♬ -
Hummmm!
Two of the same.
Isn't variety the spice of life? -
Stonecutter wrote: »Hummmm!
Two of the same.
True but i can totally see why he would want this unit in both systems. Its darn good especially for the price he got it at.
