Drain line block removal
Waste that comes out of garages, paint shops, oil and petrol refineries, shipyards and other industrial plants always get accumulate on the drain lines which are not easily carried away through the sewage lines to the deposit channel. The Drain line block removal rubbish is highly adhesive in nature and they glue on the side walls of the bilge creating drain line blockages. These machines find extensive application in drain line block removal. Applications are not limited to drain line jetting; they find application in surface cleaning, tank cleaning, paint removal, offshore cleaning and maintenance, concrete refurbishment and a lot more.
    xschop Posts: 5,729
    Have you tried an anal fissure kit? The enemas are lacking nowadays.
    Viking64 Posts: 7,762
    Dr. Pepper and hot wings will take care of that.
    xschop Posts: 5,729
    edited December 2019
    Viking64 wrote: »
    Is that method a DIY, Mod, or Tweak?
    audioluvr Posts: 6,051
    Wait, are spammers even creating their own discussions now?
  • ptrooper
    ptrooper Posts: 535
    These commercial areas should have grease traps installed and cleaned out when full !
