Need home theater sub
muncybob
My insurance claim is about done and time to replace the old Mirage Omni 12. Willing to drive reasonable distance from zip 17701. Looking to stay well under $500 since home theater sub is not that important to me and hoping to get a sub for the 2 channel soon.
Yep, my name really is Bob.
Funny you should bring this one up, I was just looking at it! Is the amp digital? Does it really matter?Yep, my name really is Bob.
Parasound HCA1500A(indoor sound) and HCA1000(outdoor sound), Dynaco PAS4, Denon DP1200 w/Shure V15 Type V and Jico SAS stylus, Marantz UD7007, Polk L600, Rythmik L12 sub. -
It's right at the cap of your budget but it includes free shipping and outside of used and abused, you probably won't find a better product at a comparable price...
https://www.svsound.com/products/pb12-nsd
Though I agree that this sub is hard to beat NEW for the $$$, I owned that mirage and it’s larger porter cabinet will put out significantly more bass in the ever important for HT 30-50hz region vs the sb12. This one will match your old subs output in that region and will destroy the old sub (and the sealed svs) in the 18-30hz region, which has become much more important for blu ray viewing:
https://www.svsound.com/products/pb12-nsd?wiz_medium=cpc&wiz_source=google&wiz_campaign=Adhoc Promotions&wiz_term=pb12 nsd subwoofer&gclid=CjwKCAiAlajvBRB_EiwA4vAqiBaW2zHfes4CCVXurvOHZ2lPctUsFeWrTIQndtaHAy0GzkOpp_mp7BoCmXIQAvD_BwE
I should have mentioned that the room is fairly small(12X16) with low ceiling. What about a Polk Audio PSW505?Yep, my name really is Bob.
Bob - I may have something that would work for you. Let me check when I get home and get back to you. I'm reasonably close to you (Bellefonte) - only about an hour or 1.5 hour drive.
-Al -
If you're really not that picky its probably fine. But I would look for something like an Energy s10.2 or Mirage LF150. Both are cheaper on the used market with tighter bass and will give you similar extension and output...Living Room 2.2: Usher BE-718 "tiny dancers"; Dual DIY Dayton audio RSS210HF-4 Subs with Dayton SPA-250 amps; Arcam SA30; Musical Fidelity A308; Sony UBP-x1000es
Insurance company said check is in the mail so I'm looking in earnest now.
Al, if you have something it happens that I'll be in your backyard next week.Yep, my name really is Bob.
I had one before I got my HSU. The bass wasn't clear like Ryan said above. There also have been a fair number of people who had amp issues with them.
I wouldn't buy one again.
Yamaha RX-A2070, Musical Fidelity M6si integrated amp, Benchmark Dac1, Bluesound NODE 2i, Audiolab 6000CDT CD Transport, Parasound Zphono USB Phono Preamp, Fluance RT85, Ortofon 2M Bronze, Polk L600's, L400, L900's, RC80i's, SVS 3000 Micro, Audioquest Interconnects and Digital Cables, Nordost Silver Shadow Digital Cable, Cullen Gold and Crossover Series Power Cables, Douglas Connection Alpha 12AWG OCC Speaker Cables, Douglas Connection Alpha Analog Interconnect Cables, Douglas Connection Alpha 11 OCC Custom Power Cable, Signal Power Cable, Furman PL-8C 15 Power Conditioner, Sony 65" 900F, Sony UBP-X700, Fios, Apple TV 4K, Audioquest Chocolate HDMI Cables. SnubWay, Main Stream -
Hey Bob - just sent you a PM!
