NHT Subone or Boston PV800?
Dannieboiz
Dannieboiz Posts: 242
Which one of the 2 subs would you choose? Even though the NHT Subone is only a 10" the footprint is the same as the 12" of the PV800. The NHT seems to have more raving reviews but the PV800 is the opposite. I purchased the Subone but also have the opportunity to buy the PV800 not sure if I made the right just since I didn't get to hear the pv800. Subone is front firing sub and the PV800 are down firing. Which is better? It'll be placed in a room with tile foor in the corner of an between the L shape sofas. Down firing subs seems to vibrate the room a little more, no?
Sammy UN55C6400
Onkyo TX-SR875
Def Tech: Mythos One, Three, Six
Velodyne DPS-12
MartinLogan Dynamo 10
Post edited by Dannieboiz on
  • Dannieboiz
    edited January 2005
    no one really cares about any of these subs?
    Sammy UN55C6400
    Onkyo TX-SR875
    Velodyne DPS-12
