Any tips on choking down this
  • verb
    verb Posts: 10,176
    Lol! You guys got way down into the ditch! :smile:
    pitdogg2 Posts: 27,198
    verb wrote: »
    At least we didn't go muddin😆
  • delkal
    delkal Posts: 764
    I think Afterburnt stopped posting for the night. He must be busy................
  • Jazzhead
    Jazzhead Posts: 526
    Poor man... Anyway, if you surface in time to use this (or next time). Someone told me to take a bite on a lemon in between gulps. It helps get your brain back between the lines if you feel like you might blow. It helped me. Hope you get some sleep. Good luck.
    Stop moanin' Bruce, when it comes to Colonoscopy, you can do it the easy way, or the hard way. You want them to use a hand drill instead ? Or a Gerbil with a go-pro strapped to it's head ? :)
