WTB - Used 2 or 3 Channel Amp for RTI12's
mtheeb
Hello,
I am in the market for a 2 or 3 channel amp to run my 2007 Polk RTI12's, maybe a 3rd channel to run the center as well. I am currently running an Onkyo 818 and with all of the research I have done it sounds like a separate amp would make quite a bit of difference in sound. I do agree my RTI12's are really bright, so would like to pair with an amp that would tame them.
Thanks,
Mike
Thanks,
Mike
A NAD 2400 PE should do the trick, or the C906(?) 6 channel bridgeable.
Don’t bridge the feed to those speakers.
Parasound 1203 or Rotel 993 - both stout 3 ch amps. If you come across a stout 5 Channel - no harm, no foul leaving two channels unused. I tri-amp my center w/a 5 ch RotelSamsung 60" UN60ES6100 LED Outlaw Audio 976 Pre/Pro Samsung BDP, Amazon Firestick, Phillips CD Changer Canare 14 ga - LCR tweeters inside*; Ctr Ch outside BJC 10 ga - LCR mids, inside* & out 8 ga Powerline: LR woofers, inside* & out *soldered LR: Tri-amped RTi A7 w/Rotels. Woofers - 980BX; Tweets & “Plugged*” Mids - 981, connected w/MP Premiere ICs Ctr Ch: Rotel RB981 -> Bi-amped CSi A6 Surrounds: Premiere ICs ->Rotel 981 -> AR 12 ga -> RTi A3. 5 Subs: Sunfire True SW Signature -> LFE & Ctr Ch; 4 Audio Pro Evidence @ the “Corners”. Power Conditioning & Distribution: 4 dedicated 20A feeds; APC H15; 5 Furman Miniport 20s *Xschop's handy work -
Hello,
Thanks for your responses back. I ran across this HCA 2003A on Ebay, the price looks a little high and there are no returns, would this be an acceptable amp and any worries about buying a used amp of Ebay like this?
https://www.ebay.com/itm/Parasound-HCA-2003A-Rack-mount-High-Current-3-Channel-Amplifier/143428364632?hash=item2164ff2958:g:IE8AAOSw2BFdAXDX:sc:USPSPriority!83642!US!-1#rpdCntId
Thanks -
*almost always higher distortion.
Those speakers really like current. I’m sorry for my generalized thinking/advice. I’m a NAD* fan me self - I have several pieces of early 80s gear*.
Tony
Great choice**! Wait for others to chime in on the $ - I think its a little high* but I’m far from an expert on their used “up-the-line” equipment pricing. I own several of their lower end items, 2 HCA 1000s*** & an 855.
* plus $100 to ship
** you’d need a much bigger pile of $ to upgrade from that
*** Same designer, less compromise
Patience will reward you sir...
TonySamsung 60" UN60ES6100 LED Outlaw Audio 976 Pre/Pro Samsung BDP, Amazon Firestick, Phillips CD Changer Canare 14 ga - LCR tweeters inside*; Ctr Ch outside BJC 10 ga - LCR mids, inside* & out 8 ga Powerline: LR woofers, inside* & out *soldered LR: Tri-amped RTi A7 w/Rotels. Woofers - 980BX; Tweets & “Plugged*” Mids - 981, connected w/MP Premiere ICs Ctr Ch: Rotel RB981 -> Bi-amped CSi A6 Surrounds: Premiere ICs ->Rotel 981 -> AR 12 ga -> RTi A3. 5 Subs: Sunfire True SW Signature -> LFE & Ctr Ch; 4 Audio Pro Evidence @ the “Corners”. Power Conditioning & Distribution: 4 dedicated 20A feeds; APC H15; 5 Furman Miniport 20s *Xschop's handy work -
Hello,
It’s a bit high, but those are rare so not as much to compare to.
I bought a rotel RB993 for $600 shipped, great amp at what I think was a fair price a couple years ago.
Where are you located? I might have something for you...Living Room 2.2: Usher BE-718 "tiny dancers"; Dual DIY Dayton audio RSS210HF-4 Subs with Dayton SPA-250 amps; Arcam SA30; Musical Fidelity A308; Sony UBP-x1000es; Squeezebox Touch with Bolder Power Supply
Bedroom 2.1Cambridge Azur 551r; Polk RT25i; ACI Titan Subwoofer -
Here is a RB993. Not sure if they will ship but might be worth a call.
https://www.chelseaaudiovideo.com/clearance-equipment-inventory/2 Channel
Pre:Bryston BP173
Amp:Bryston 14B3
Speakers: Golden Ear Triton Reference
Source: Oppo UDP-205, Bryston BDA-3, Bryston BDP-3, Bryston BCD-3, Apple TV, Amazon Fire
Cables: Wireworld Gold Eclipse 7 Speaker, Wireworld Gold Eclipse 7 XLR, AQ Diamond USB/HDMI
Power: PS Audio P10 Regenerator, AC12, AC10 and AC5 Cables
Display: Sony XBR65Z9F
Pre: Anthem AVM90/JBL SDP-55
Amps: Parasound A31, A51x2
Speakers: Polk LSiM 707 (FL/FR), Polk LSiM706 (Center), LSiM 703 (SL/SR/SBL/SBR), Polk 900-LS (Atmos)
Subwoofers: SVS SB16 x 4
Source: Oppo UDP-205, Apple TV, Amazon Fire
Cables: AQ Meteor/Rocket 88, AQ Niagara/Sky
Power: Torus AVR20, Shunyata Denali, Shunyata Delta, Cullen, PangeaAC9SE Cables
Display: Sony XBR85Z9G -
Winner! $300 for that amp is a bangin' price. -
If you're still looking... I have a Parasound HCA-806 that might be a decent fit. I used it for a few years with RTi12's and, later, RTiA9's in a master bedroom HT. Warmed them up nicely. That rig was SO much fun. Used most recently to run 3 pairs of Polk in-wall satellites.
I bought it used in '12. Still going strong. Bridgeable channels (never tried). Scuffs and scratches, one noisy pot, very good sound.
Info: https://parasound.com/vintage/hca806a.php [Edit: This link shows info on the A version. Not sure how they differ]
Pics: https://photos.app.goo.gl/3hcBCsMxZ6uLX2pVA
$275+shipping.
You can return in same shape if not happy. "craigw29" on ebay since '98.
Craigb]Beach Audio[/b]: Rega RP6 (mods) - AT33PTG/II - Parks Budgie SUT - PSAudio NPC * Eversolo DMP-A6 * Topping D90iii * Joule-Electra LA-100 mkIII * Pass Aleph 30 * MIT S3 * Polk SRS 2.3tl (mods) * PSAudio PPP3
Town Porch: WiiM Pro Plus * Sunfire Sig II * Canare 4S11 * Magnepan 1.6 * Dectet -
Than you everyone for your responses. @vcwatkins - I'm looking for something that powers 200w+ per channel unfortunately. @spgmsmg - I reached out and it sold already. That sounded perfect.
Still open for ideas if anyone comes up with anything! -
Are you still in the need? Have a Parasound HCA 1500A I might part with.Main Rig:
Nakamichi EC100 Active xover
MIT exp 1 ic's
Perreaux SA33 class A preamp
AQ kingcobra ic's
OPPO 83 CDP
ADS L1590/2 Biamped
MIT exps2 speaker cable
