Question about CRS speaker placement
TennMan
Distance from the rear wall makes a lot of difference in my 2BTLs but not so much on my CRS+. Wondering how far other CRS owners have their speakers out from the rear wall?
- SDA 2BTL · Sonicaps · Mills resistors · RDO-198s · New gaskets · H-nuts · Erse inductors · BH5 · Dynamat
- Crossover upgrades by westmassguy
- Marantz 1504 AVR (front speaker pre-outs to Adcom 555)
- Adcom GFA-555 amp · Upgrades & speaker protection added by OldmanSRS
- Pioneer DV-610AV DVD/CD player
- SDA CRS+ · Hidden away in the closet
As stated in Polk manual. The CRS+ speakers are designed for shelf or stands. They can be brought out some. I keep mine about 12 inches out. I did play around with placement after I did upgrades a few years ago. Try different positions away from wall to your likings..
Randy/Maine -
boston1450 wrote: »As stated in Polk manual. The CRS+ speakers are designed for shelf or stands. They can be brought out some. I keep mine about 12 inches out. I did play around with placement after I did upgrades a few years ago. Try different positions away from wall to your likings
I found mine worked well at about 15 inches out.
I'm surprised that moving the CRS off the back wall 12-15" would be the ideal placement. Seems like it would kill the bass on the little guys. Are you guys using a sub with them?
It may not for you.... I use my Cs1000p sub on HT only. The subs are in the center speaker & the dial isn't up high. I dont require the thump as some here like. My room is also 18×26...
Randy/Maine
