SDA 1 Blade/Pin interconnect cable wanted
ultrasoudproductions
Hello fello Olkaholics,
I have come across a set of Polk DSA 1 speakers, but the Blade/Pin interconnect cable is missing. Does anybody have a set lying baround that may want to get rid of or know of where I can find a set.
What price are the OEM ones going for? I now own 2 dreadnaughts and a A-1, and have a couple of cables stashed somewhere.Home Theater
Thank you pitdogg, I did see those but did not have the blade so wasn't sure that it would work. -
Hello gudnoyez,
I am not finding the OEM, nor have I called Polk yet. What would be asking if you have a set? PM ME.
THANKS -
You do not need the blade. On the regular pin blade cable the blade is just for support only the pin carries the signal. The blade just goes to ground(blk binding post) inside. If you're wanting to use non common ground or monoblock amps you're going to need a AI-1 interface cable. But most of us have built the dreadnaught for that.
