DIY 12v trigger output ..
gyosa
So , this thing doesn’t have a 12v trigger out ..
I’m gonna make one using one of the USB ports ....
We’ll see if it works ......
Bk
Bk
PS Audio S300 , WiiM Ultra , Yamaha wxc-50 , Salk SuperCharged Songtowers , Kimber Kable 4TC, Sony 48” - BEDROOM
B&K EX-442 ( it will go in my casket when I die ... ) , PS Audio 4.6 preamp ( old school , but it still jams on ... ) , Eversolo DMP-A6 , Boston Acoustic voyager 7’s - POOL
Parasound A21, Eversolo DMP-A8 , Kimber Kable 4vs , Ascend Acoustics ELX Ribbon Towers , Sony XBR-A8F 65” OLED - DEN , MAIN system
Onkyo TX-nr609 , Polk atrium 7 , Boston acoustic sound ware (4) , Boston acoustic sub , B&W center , Sony 65” TV - PATIO
Just tried it .....
Works perfect !
The 851 USB ports output power....
Cut the end off a USB cable , stripped the sheath off ....
The green and white are data , the red and black are power , black being ground.
Spliced the usb power wires to a mono 3.5mm jack cable and presto , 851 now has a 12v trigger out !! Snip the green/white wires , wrap rest with electrical tape or whatever to make pretty ...
Turns the amp on and off !
It would probably work with anything , TV’s etc , that has a powered USB port ....
Bk
Onkyo TX-nr609 , Polk atrium 7 , Boston acoustic sound ware (4) , Boston acoustic sub , B&W center , Sony 65” TV - PATIO -
I thought the power lines on USB were 5V (??).
PS Get yourself some heatshrink tubing to "finish" it like a pro!
I can send you some if you don't have any, are loath to purchase some and if you live in the US and want to PM me an address
That would be great !
I’ll pm ya .....
USB ports ARE typically 5v - that’s the usb standard ....
Most trigger inputs will work with less than 12v ..... usually anywhere from 5-12 v...
There is no standard for trigger inputs from what I gather .
All I know is it works perfectly !
Bk
Can't beat empiricism! I "assumed" that was what was goin' on (i.e., voltage promiscuity on the part of the trigger, so to speak).
Just in case anyone else is interested...
Personally , I think this is a potentially great problem solver for some ...
I know it was for me ...
I figured it out after I found this , knowing a USB port had power ....
Bk
Voltage promiscuity lolLiving Room 2.2: Usher BE-718 "tiny dancers"; Dual DIY Dayton audio RSS210HF-4 Subs with Dayton SPA-250 amps; Arcam SA30; Musical Fidelity A308; Sony UBP-x1000es
well, it's like frequency agile, you know?
5 VDC... 12VDC... whatever it takes to turn 'er on, you know?
Nods as good as a wink...
