DIY 12v trigger output ..
So , this thing doesn’t have a 12v trigger out ..
I’m gonna make one using one of the USB ports ....
We’ll see if it works ......
PS Audio S300 , WiiM Ultra , Yamaha wxc-50 , Salk SuperCharged Songtowers , Kimber Kable 4TC, Sony 48” - BEDROOM
B&K EX-442 ( it will go in my casket when I die ... ) , PS Audio 4.6 preamp ( old school , but it still jams on ... ) , Eversolo DMP-A6 , Boston Acoustic voyager 7’s - POOL
Parasound A21, Eversolo DMP-A8 , Kimber Kable 4vs , Ascend Acoustics ELX Ribbon Towers , Sony XBR-A8F 65” OLED - DEN , MAIN system
Onkyo TX-nr609 , Polk atrium 7 , Boston acoustic sound ware (4) , Boston acoustic sub , B&W center , Sony 65” TV - PATIO
  • gyosa
    gyosa Posts: 770
    edited October 2019
    Just tried it .....
    Works perfect !
    The 851 USB ports output power....
    Cut the end off a USB cable , stripped the sheath off ....
    The green and white are data , the red and black are power , black being ground.
    Spliced the usb power wires to a mono 3.5mm jack cable and presto , 851 now has a 12v trigger out !! Snip the green/white wires , wrap rest with electrical tape or whatever to make pretty ...
    Turns the amp on and off !
    It would probably work with anything , TV’s etc , that has a powered USB port ....
    mhardy6647 Posts: 35,526
    edited October 2019
    I thought the power lines on USB were 5V (??).
    PS Get yourself some heatshrink tubing to "finish" it like a pro! ;) I can send you some if you don't have any, are loath to purchase some and if you live in the US and want to PM me an address :)
  • gyosa
    gyosa Posts: 770
    That would be great !
    I’ll pm ya .....
    USB ports ARE typically 5v - that’s the usb standard ....
    Most trigger inputs will work with less than 12v ..... usually anywhere from 5-12 v...
    There is no standard for trigger inputs from what I gather .
    All I know is it works perfectly !
    Bk
    Can't beat empiricism! I "assumed" that was what was goin' on (i.e., voltage promiscuity on the part of the trigger, so to speak). :)
  • gyosa
    gyosa Posts: 770
    edited October 2019
    Just in case anyone else is interested...
    Personally , I think this is a potentially great problem solver for some ...
    I know it was for me ...
    I figured it out after I found this , knowing a USB port had power ....
    Bk
  • rooftop59
    rooftop59 Posts: 8,120
    Voltage promiscuity lol
    Game Room 5.1.4:
    Bedroom 2.1
    rooftop59 wrote: »
    well, it's like frequency agile, you know?
    5 VDC... 12VDC... whatever it takes to turn 'er on, you know?
  • joecoulson
    joecoulson Posts: 4,978
    Nods as good as a wink...
