Anyone into amateur astronomy
24
  • verb
    verb Posts: 10,176
    Patience grasshopper! CL is your friend! :smile:
  • joecoulson
    joecoulson Posts: 4,943
    I will say I got the deal of a lifetime on that scope in the pic, its about a $6k rig I got for about $1500. If you find the right seller, you can get the very last scope you would ever need.
    mhardy6647 Posts: 34,958
    edited October 2019
    afterburnt wrote: »
    Yeah, I like to do that, too. In fact...
    The same partial eclipse, observed via the little slots for the strings in our blinds :p
    (sorry it is sideways)
  • verb
    verb Posts: 10,176
    I did the pinhole in a cardboard box thing during the last eclipse. Brought back childhood memories for sure! :smile:
  • verb
    verb Posts: 10,176
    Found the pic! I was reminded that we were in the middle of moving, so no chance to do anything else! Plenty of moving boxes around! :smile:
  • maximillian
    maximillian Posts: 2,149
    edited October 2019
    Buying used will save you some coin. Make sure you ask yourself if you want to get into astro-photography. If so, an EQ is pretty much a must. I have the Celestron 8SE that a friend recommended but it's limited for photography. The wedge is an option, but you might as well get the EQ if photographing is your plan. Someday I will have to buy a better mount.
    Take your time and research the gear that gets your what you want to see. Also, this is a hobby of patience. Finding the right viewing position, viewing conditions and time of year for the object you are looking for take patiences. Light pollution is the enemy of all, and difficult to get around in most areas. You will need good filters.
    I am still trying to get a good view of Jupiter. Perhaps it's just the time of the year (it's low in the horizon) and my choice of gear may not be optimal. As of a couple weeks ago I only got a bright blob of a view. I could see some of Jupiter's moons but could not make out the bands. Now that I have better filters I am patiently waiting for a non-cloudy day.
    I have spent nearly double on accessories compared to the 8SE's base price. Better secondary optics, battery pack, upgraded 2" diagonal, a Baader zoom eyepiece, Baader barlow lens, better finder scope, a focus motor, vibration isolation pods, and a bunch of other stuff. And setting this stuff up everytime I want to view is a little bit of a pain. I may need a dolly system next.
    The scope needs to be aligned which takes a few minutes eachtime. I got a little lazy and bought the StarSense camera. Probably would have been better to take the time and learn to do it properly. But with light pollution and initially not having a good finder scope, the StarSense camera helped with some initial frustration.
    Many people get into this hobby and don't have the patience. That's why you see scopes with little use on CL. Lot of pain in this hobby: clouds, light pollution, and cold weather. But it is fun and rewarding once you learn what your looking at and get some nice images.
    ^ excellent response! :)
    FWIW, Jupiter was phenomenal throughout the summer.
    Astrophotography. :) The problem, of course, is that it's dark at night and the earth rotates. Thus a properly aligned equitorial amount and a clock drive are necessities "for best results". :|
    In terms of light pollution, there are a couple of "high tech" :) filters that are supposed to help a lot for things like nebulae -- I have zero experience with 'em myself; @maximillian do you?
    These kind of things:
    https://www.telescope.com/Orion/Orion-SkyGlow-Broadband-Light-Pollution-Filters/rc/2160/e/3.uts
    https://www.telescope.com/Orion/Orion-UltraBlock-Narrowband-Filters/rc/2160/e/71.uts
    https://www.telescope.com/Orion/Orion-Oxygen-III-Nebula-Filters-for-Eyepieces/rc/2160/e/27.uts
  • joecoulson
    I have a Baader Moon and sky filter that helps tremendously for the light pollution, but it's not cheap.
    I also have the wedge for my Alt Az mount and it works good for about 30 sec exposures, DSO photography is better served with a good Refractor and even better EQ mount.
    Jupiter was looking absolutely phenomenal this past month, plenty of nights I got the red spot, cloud bands and even the shadow of a couple of the Galilean moons in transit.
  • afterburnt
    afterburnt Posts: 7,892
    Will that GoTo mount automatically track? I am having a hard time finding details on the one that I linked.
  • joecoulson
    Per the link you posted:
    FULLY-AUTOMATED GOTO MOUNT: Featuring a database of more than 40,000 celestial objects, the GoTo mount built into our telescopes for astronomy beginners automatically locates and tracks objects for you.
    Yes it will track, you will have to do a one or two star alignment so get a decent app for your smart phone like Skyguide or similar to help you locate two stars while you get familiar with the sky.
    joecoulson wrote: »
    cheaper than moving :)
  • maximillian
    I just got the 2" Baader Moon and Sky filter and attached it to the diagonal. But I just got it and it's been cloudy for over a week. :-( It's supposed to be nice out tonight, but I have evening meetings. Double :-(
    I think the white Jupiter glob that I saw a few weeks ago was simply because I had too much light. Hopefully the filter will help.
    I contemplated getting the wedge instead of going full EQ. I heard some can get 120 seconds with the wedge but not sure if all my gear makes the secret sauce to get there.
  • jdjohn
    jdjohn Posts: 3,337
    Here in Nashville, we were near the center of the last full eclipse path. Our weather cooperated, and the sight was simply amazing...I felt the need to make a human sacrifice, but resisted. Crickets were chirping in the middle of the day, etc. I did get this pic:wl6vtnkpmqyb.jpg
    I kind of enjoy the Google Sky Map app.
  • joecoulson
    That filter is bad azz max. I got the 2” also.
    It goes well with my kit
    ^^^ nice optics :)
  • maximillian
    edited October 2019
    My gear:
    You can see the Baader diagonal and zoom eyepiece. I also have the Baader Barlow lens but not sure how to use it with this gear. If I attach to the zoom and try to insert into the diagonal then it will hit the mirror. The filter is attached at the entry to the diagonal.
    The camera top right is the StarSense alignment camera. Again, probably not worth it but it does make alignment pretty brain dead. I have the attachments to mount my Nikon DSLR but haven't tried it yet. Actually, haven't tested the diagonal and focus motor either since between the weather and work I just haven't had the opportunity . The Click-lock system makes switching stuff around fast and easy. It feels really sturdy.
    The finder scope is the basic Celestron upgrade but does the job well enough. The Suaoki jump starter battery pack has a 2.1mm barrel jack 12V output and works great.
    It's small and seems to have enough juice to last a while. On night after 2 hours of use the battery was still at 87%.
    I have a backordered JMS Holder Bracket for the hand controller. I am starting to think they may be out of business because they don't answer emails.
  • joecoulson
    Nice setup.
    Have you had much time with that diagonal? Thoughts vs the stock if so?
  • maximillian
    Not enough time with it yet, but the ClickLock system is sweet. The Baader zoom eyepiece can be used with the stock 1.25" diagonal or 2". It's pretty awesome and well worth the money.
  • joecoulson
    I recently purchased a visual back - meaning an attachment allowing fixture of the eyepiece at the back of the OTA without a diagonal.
    Now this only works with objects at 50deg or less from horizon (or thereabouts) but the views were noticeably clearer than my diagonal - and I have the upgraded Meade version.
    Makes me wonder if a Televue or higher end Dieletric Diagonal would be worth the coin?
    tonyb Posts: 33,069
    Those scopes look nice. Everyone I know who has one though, goes the way of a treadmill....sits in a corner unused.
    I know Russ is from outer space, so pretty sure he's into this stuff. Actually, I am too, just don't want to shell out the coin for a nice scope. FB marketplace usually has some nice ones under 500, so if any of you guys are looking for some nice glass on the cheap, look there.
    BTW- those automatic star finder things are the way to go, unless all your going to use your scope for is looking at the moon or your hot neighbors window.
    Viking64 Posts: 7,536
    tonyb wrote: »
    ....your hot neighbors window.
    At first I read that as "your hot neighbor's widow." :o
    tonyb wrote: »
    Viking64 wrote: »
    A spotting scope is preferred for these applications -- as they provide an image that's erect.
    32309402044_d53d70104a_b.jpgDSC_7238 (2) by Mark Hardy, on Flickr
    Not that I am advocating any activities along these line, mind you -- and I will mention that spotting scopes are very useful for observing birds and other critters in one's backyard. :)
    tonyb Posts: 33,069
    so....that's the cover story you tell the wife eh ?
    Might have to take up...cough cough...."birding" myself.
    say no more, say no more!
  • maximillian
    edited October 2019
    tonyb wrote: »
    If you have the money or lack the patience, then sure. When I first started using the scope I got a little frustrated. This was part due to light pollution, a lack of patience, and unfamiliarity with the gear. So I broke down and bought one. Aligning is super simple with it.
    However, once you learn the sky and know what you are looking at (which is part of the point of the hobby) and you have a good finder scope, then they become unnecessary. It take the StarSense 3-4 minutes to get aligned, but someone who is into the hobby and knows the sky can align in 5-6 minutes.
    With limited funds it's better to put the money to filters and optics.
    gudnoyez Posts: 8,160
    edited October 2019
    https://youtu.be/7xXEtO3bEe0
    My Astonomy fascination is camping in the Northwoods staring into the heavens with this playing loudly in the background.
    Astronomy https://g.co/kgs/35qpA2
    edited October 2019
    gudnoyez wrote: »
    "Workshop of the Telescopes" from their first album also works well. :p
    edited October 2019
