Ordered a Cambridge 851n today .....
We’ll see how it sounds 😊
It’ll be here next week .....
Bk
PS Audio S300 , WiiM Ultra , Yamaha wxc-50 , Salk SuperCharged Songtowers , Kimber Kable 4TC, Sony 48” - BEDROOM
B&K EX-442 ( it will go in my casket when I die ... ) , PS Audio 4.6 preamp ( old school , but it still jams on ... ) , Eversolo DMP-A6 , Boston Acoustic voyager 7’s - POOL
Parasound A21, Eversolo DMP-A8 , Kimber Kable 4vs , Ascend Acoustics ELX Ribbon Towers , Sony XBR-A8F 65” OLED - DEN , MAIN system
Onkyo TX-nr609 , Polk atrium 7 , Boston acoustic sound ware (4) , Boston acoustic sub , B&W center , Sony 65” TV - PATIO
  • verb
    verb Posts: 10,176
    Awesome! :smile:
  • gyosa
    gyosa Posts: 770
    edited October 2019
    Skip ,
    I appreciated your thoughts regarding my other post !
    I looked online at the D1 you mentioned...I likey ...
    Then I thought to myself - well maybe the U1 mini would definitely be a better choice ..... lack of WiFi and a physical volume knob was problematic , although I could hardwire it if need be or use a WiFi extender...but no optical or coax Input on either one.
    Then I saw the 851n was available as a refurb from Cambridge- 900 scheckels ....
    Couldn’t resist .....
    If I don’t like it , I can return it and look at a Lumin.....
    The plan is to use the Cambridge for Tidal , plug the wxc-50 into the 851 via optical or coax , and use the wxc-50 for SIRIUSXM streaming through the 851 - which I listen to a lot ....
    My dilemma was I wanted a quality streamer that gave me both Tidal and SIRIUSXM- the only 2 things I listen to ....
    Hopefully using the 851’s DAC and preamp to stream the horribly compressed SIRIUSXM will be satisfactory....
    We shall see ....
    Bk
    Post edited by gyosa on
    audioluvr Posts: 6,013
    Congrats. Love mine. Using it as a pre seemed a little too bright for me but you may have different results with your equipment. I really enjoy using Tidal via my laptop and a USB cable.
  • verb
    verb Posts: 10,176
    Have not used the preamp function on mine, only as a streamer.
  • gyosa
    gyosa Posts: 770
    Was supposed to be delivered yesterday .....
    After sitting in Pennsylvania for the last 6 days , UPS admitted they “lost” it ......
    Hopefully a replacement will be shipped soon .....
    Bk
    Clipdat Posts: 13,100
    What can brown do for you?
  • gyosa wrote: »
    Bk
    Ugg that sucks...let us know how that unfolds
  • That blows. Listening to mine now, it will be worth the wait.
    Living Room
    Parasound HINT 6, Yamaha Aventage RX-A 1060, Oppo 103D, Cambridge Audio Azur 851N, KLH Model 5s, Polk CSi A6, Samsung 65" LED
    Office
    Yamaha A-S501, Auralic Aries Mini, LSiM 703s
    Douglas Connection ICs and Cables
  • tophatjohnny
    tophatjohnny Posts: 4,189
    So glad you are still digging it brother. I enjoyed my time with the 851N too. Great way to get an idea of how streamers work for sure and the app is pretty user friendly too.
  • verb
    verb Posts: 10,176
    Rocking my 851N right now through the VTL pre, loving it! :smile:
    DSkip wrote: »
    audioluvr wrote: »
    Wait. What? Why are you using the laptop if you have the streamer?
    Sorry Skip, should have clarified that I'm using my laptop with Tidal app linked to the CA 851N via USB cable.
  • ThomasD
    ThomasD Posts: 260
    @verb
    Lovin' those chrome legs on your Mc stands. Are those custom made or available somewhere?
    Carver M4.0t, M1.0t, M200t, TX2, C1, C2, Marantz 2230, 2010, 4070, 1030, APPJ 2013, Rega Brio, Marantz Imperial 7's, Klipsch Heresy III, Quartets, KG4's, KG1's, 'The Sixes', R-12SW, Polk SDA 2a's, Monitor 7cTL's, SDA CRS's, 4a's, Zu Audio Dirty Weekends, Pro-ject Acryl TT, Cambridge 851N, 351C, Panamax 5300PM
  • verb
    verb Posts: 10,176
    ThomasD wrote: »
    @verb
    Thanks! Got em on eBay, just do a search for sofa legs, metal, and there are a bunch of different types. I like these as they have threads on the bottom for the included feet, but you could spike em too!
  • ThomasD
    ThomasD Posts: 260
    @Verb Thanks, been using heavy 1/2" hairpin style legs of different heights because of my wife's preference but those look pretty cool.
  • gyosa
    gyosa Posts: 770
    Or even to the 851 via UPnP , right ?
    Bk
    DSkip wrote: »
    audioluvr wrote: »
    DSkip wrote: »
    audioluvr wrote: »
    Why? You’ll get better sound if you use tidal direct with the Cambridge app.
    DSkip wrote: »
    audioluvr wrote: »
    DSkip wrote: »
    audioluvr wrote: »
    Possibly, but the navigation sucks compared to Tidal's app that I can use on my laptop while surfing the internet
  • rooftop59
    rooftop59 Posts: 8,120
    audioluvr wrote: »
    DSkip wrote: »
    audioluvr wrote: »
    DSkip wrote: »
    audioluvr wrote: »
    Do you have tidal settings set to take control of volume in windows? Have you done a side by side comparison of the SQ of the Cambridge app vs the windows app?
    Game Room 5.1.4:
    Bedroom 2.1
    Cambridge Audio doesn't have a windows app. The Tidal windows app is far more user friendly. As for the difference between the two sound quality wise, I haven't critiqued the two.
    As long as you are happy with the sound coming out of the speakers, then set it and forget it! :)
  • rooftop59
    audioluvr wrote: »
    I tend to agree with @Clipdat, accept when the comparison costs nothing but a little time. I assume you have a smartphone or tablet? The Cambridge app is designed for mobile devices. If it were me I would be curious to try both methods, but hey again if you're happy rock on.
    Game Room 5.1.4:
    Bedroom 2.1
  • gyosa
    gyosa Posts: 770
    Try the mConnect app ...
    K
  • verb wrote: »
    ThomasD wrote: »
    @verb
    Verb, I've seen the sofa legs on several websites including eBay. I am interested in where you buy the butcher block to make them. Online? I need to make a riser stand that is about 48 inches wide. It may require legs in the middle too. Thanks in advance.
    Harry / Marietta GA
  • gyosa
    gyosa Posts: 770
    Replacement 851n should arrive today ...
    Bk
  • verb
    verb Posts: 10,176
    verb wrote: »
    ThomasD wrote: »
    @verb
    Sorry brother - just happen to run across this. Got the butcher blocks on-line, pre cut, and seasoned with oil. I'll PM you the link!
