Durango R/T K&N CAI system
mantis
Hello everyone,
As some of you may know my best Stock 1/4 mile run was a 14.1 @96.5MPH. This is as far as I know the faster stock 1/4 mile R/T Durango in the country.
I did this run with 1 mod which most will say does absolutely nothing was a drop in replacement K&N Air filter. When I did the drop in I felt a slightly better throttle response but I didn't think it was any faster. This was 2 years ago when I got it new.
Today I decided to go with the full CAI system from K&N which is part number 63-1563 and I installed it in like 20-30 minutes tops. Super easy to install, everything fits perfectly and taking out the factory system took all about 2 minutes. A few bolts and it's out.
One thing I noticed so far is the feel. It feels like under normal non full throttle driving I gained a slight effortless feeling. Now ECO mode feels more responsive where before it felt slightly sluggish compared to ECO OFF and or SPORT MODE.
The Sound at wide open throttle is insane. Driving around with the resonator style intake factory system I didn't realize now much sound it cancels out. That has to be some what restrictive as it's a giant difference in sound. When you mash the gas it goes crazy, it's loud.
I'm excited to get back to the track, my Son is trying to beat is best time of 12.6 @110 with his Audi S4 stock with a CAI.
Dan
So does that just pull the hot air from under the hood or is there something that grabs cooler air from outside the motor compartment?
Hot. The shield helps a little.afterburnt wrote: »They didn't speak a word of English, they were from South Carolina.
Village Idiot of Club Polk -
It pulls cold air from outside and from under the hood. The heat shield doesn't completely shield it from all under hood air. The seal does seal against the hood and keeps a lot out but it should have been designed to shield out all of it.
When you make passes at the track, you do it with a cool engine not hot like you drove it for 20 minutes or more.Dan
I tried a K&N power pipe for my F150 4.6 and because of it grabbing the hot air from engine compartment it played h ell with my mass air sensors. I had to remove it. If it could be 100% covered and had access to cooler outside air (like newer mustang's) I feel it would have worked much better.
Mine looked a lot like that one, -
Do you guys have any videos of your passes?afterburnt wrote: »They didn't speak a word of English, they were from South Carolina.
My 68 442 the cold air intakes are mounted under the front bumper.
It gets nothing but cold air as well as leaves, bugs and the like.Patriotism is the last refuge of a scoundrel…….Samuel Johnson
– Kevin Alfred Strom -
Dan
I dropped in a pre-oiled K&N filter in my car. (2.0T). Did notice a slight increase in performance.
I put a bag of rice in the back seat of my Civic hatch. Did not note any improvement.afterburnt wrote: »They didn't speak a word of English, they were from South Carolina.
Your supposed to put the Civic in the bag of rice my manDan
https://www.youtube.com/watch?v=W-kxITS8wKM
