800va Dreadnaught with case and cables
pitdogg2
For Sale is my 800va Avel-Lindberg Dreadnaught in an aluminium case with a small sheet of sound dampener. The case holds the torrid very tight as it is barely bigger than the torrid with no need for a bolt to hold it in place. This is plug and play. It is set up to use the Pin/Blade socket (RCA Pin) and the negative binding post on SDA's. If you only have one set of binding post on your SDA's just switch the speaker end banana to a spade if needed and you are good to go. I've used this for about 2yrs and it works very well. The cable appears to be an Audioquest cable and it well built. I used it for about 6mo. before I built my own so all my cable matched my speaker cable. This in case you do not know is perfect for NON-COMMON ground amps and MONO BLOC bloc amps. This also works VERY well on common ground amps for much better sound than just the interconnect cable alone.
I'm asking 200.00 plus shipping. It is the same price I paid for it from a member @trav0810.
I drove to Indiana to pick it up. It is heavy about 25lbs I'm guessing.
I accept PP friends and family only unless you and I know each other well then we can work something out with a check or money order.
I ask that you be a member here with 50 posts or more.
Post edited by pitdogg2 on
Good price Ivan! GLWTS!Just a dude doing dude-ly things
"Audiophiles are the male equivalent of cat ladies." - Audiokarma Member -
Hey brother....if nobody picks up on this in the next few days....I gotta count out my pennies in my piggy bank and I'm heading out for the weekend but I think I can make this happen.
BDT -
Sure bet brah
bump
Garage #2: Cambridge Audio EVO150 Integrated Amplifier, Polk L200's, Analysis Plus Silver Oval 2 Speaker Cables, IC's TBD. -
to the top
Troy didn't want it?Political Correctness'.........defined
President of Club Polk -
Crap...Troy does want it. Troy needs to count his pennies...gimmie a day or so but don't hold it for me......
Do I have to have a discussion with the lovely Wendi?Political Correctness'.........defined
ok, ok, ok, ok....
I'll take it.
If you would....figger up shipping to 29406 (it's a business address) and shoot me a total to my email: troy.dion@GEEMAIL.com and I'll send you a check or money order, whatever you wish.
Don't run getting it to fedex.....it will be a little bit before I get the CRS's up and running.
BDT -
Nice.... congrats to both parties.The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon MiND2 Shunyata Triton/Typhon Rotel RP9400 Turntable
ok, ok, ok, ok....
I'll take it.
BDT
'bout time dude!
Was thinking about a spare, of course!
PM sent T roy
I just reread your post.....if you prefer PayPal, I can do that too.....I was thinking you were avoiding PayPal......because it is replete with suckiocity....I plan for the future. - F1Nut
Congrats. Also glad to see this temptation gone.
