800va Dreadnaught with case and cables
pitdogg2
pitdogg2 Posts: 27,216
edited September 2019 in For Sale (FS) Classifieds
For Sale is my 800va Avel-Lindberg Dreadnaught in an aluminium case with a small sheet of sound dampener. The case holds the torrid very tight as it is barely bigger than the torrid with no need for a bolt to hold it in place. This is plug and play. It is set up to use the Pin/Blade socket (RCA Pin) and the negative binding post on SDA's. If you only have one set of binding post on your SDA's just switch the speaker end banana to a spade if needed and you are good to go. I've used this for about 2yrs and it works very well. The cable appears to be an Audioquest cable and it well built. I used it for about 6mo. before I built my own so all my cable matched my speaker cable. This in case you do not know is perfect for NON-COMMON ground amps and MONO BLOC bloc amps. This also works VERY well on common ground amps for much better sound than just the interconnect cable alone.
I'm asking 200.00 plus shipping. It is the same price I paid for it from a member @trav0810.
I drove to Indiana to pick it up. It is heavy about 25lbs I'm guessing.
I accept PP friends and family only unless you and I know each other well then we can work something out with a check or money order.
I ask that you be a member here with 50 posts or more.
Post edited by pitdogg2 on
  • Good price Ivan! GLWTS!
  • BDT
    BDT Posts: 212
    Hey brother....if nobody picks up on this in the next few days....I gotta count out my pennies in my piggy bank and I'm heading out for the weekend but I think I can make this happen.
    BDT
  • verb
    verb Posts: 10,176
    bump
    Nice looking piece!
    F1nut Posts: 51,936
    Troy didn't want it?
  • BDT
    BDT Posts: 212
    Crap...Troy does want it. Troy needs to count his pennies...gimmie a day or so but don't hold it for me......
    F1nut Posts: 51,936
    Do I have to have a discussion with the lovely Wendi?
  • BDT
    BDT Posts: 212
    ok, ok, ok, ok....
    I'll take it.
    If you would....figger up shipping to 29406 (it's a business address) and shoot me a total to my email: troy.dion@GEEMAIL.com and I'll send you a check or money order, whatever you wish.
    Don't run getting it to fedex.....it will be a little bit before I get the CRS's up and running.
    BDT
    nooshinjohn Posts: 25,978
    Nice.... congrats to both parties.
  • verb
    verb Posts: 10,176
    BDT wrote: »
    ok, ok, ok, ok....
    I'll take it.
    BDT
    'bout time dude! :) Was thinking about a spare, of course! :)
  • TroyD
    TroyD Posts: 13,124
    I just reread your post.....if you prefer PayPal, I can do that too.....I was thinking you were avoiding PayPal......because it is replete with suckiocity....
  • Congrats. Also glad to see this temptation gone.
