MIT Shotgun 2 Interconnects - 2 meter great shape
NotaSuv
$280 per pair Shipped double-boxed with original box, packaging and all literature
How many pairs do you have?The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon MiND2 Shunyata Triton
just the one pair
PM coming later.....put me in line!
will do
Lifelong MIT fan. Although I stopped after the Magnum series. I can only hear so much. I did however purchase some Oracle jumpers for my Magnepan 3.6R.CTC BBQ Amplifier, Sonic Frontiers Line3 Pre-Amplifier and Wadia 581 SACD player. Speakers? Always changing but for now, Mission Argonauts I picked up for $50 bucks, mint.
Are they still available?
had one express interest but have yet to hear back from them...…..
Sending pm
Im going to pass....just found a demo phono pre. GLWS
SOLD these are no longer available
Got them and hooked them up to my Oppo.
Definitely a difference between this one and the older white colored MIT cable I was using. Better integration between the channels. I have some S1 cables for the left and right and I am using these S2’s for the center and back surround.
Thanks much John!👍🏾 -
honestaquarian wrote: »...older white colored MIT cable I was using. Better integration between the channels. I have some S1 cables for the left and right and I am using these S2’s for the center and back surround.
Try the S2's in place of the older white S1's you have on the fronts (L/R). The newer S2's should (believe they do) have trickle down tech (ie..more poles) as newer designs were released. MIT lineage is sometimes hard to understand but I believe you might find a positive difference. I made a similar switch based on Joe Abrams (MIT reseller) suggestion.
➀Speakers: Polk1.2tl's (Uber Mods) ➁Pre/Amp/DAC: PS Audio PMG Signature Pre, BHK Signature 250, PMG Signature 512 ➂Cables/IC's: MIT S1Bi-Wire/S1 Balanced +Avel Lindberg 1000VA "Dreadnought" ➃Power Conditioner: PS Audio P15 Power Plant ➄Power Cords: Core Power Technologies Gold, DH Labs Power Plus DIY w/Neotech NC-P301 & P311ends ➅Streaming: Roon ROCK on wifi'd NUC, TP-Link WAP, & Uptone EtherREGEN, AfterDark, Emperor Double Crown Clock, Black Modernize LPS⟿Ω☯☥☮⟿🔊♩♪♫♬♩♪♫♬♩♪♫♬ -
I may have misread what you changed. After rereading it looks like you might already have newer S1's on the fronts?honestaquarian wrote: »...older white colored MIT cable I was using. Better integration between the channels. I have some S1 cables for the left and right and I am using these S2’s for the center and back surround.
Try the S2's in place of the older white S1's you have on the fronts (L/R). The newer S2's should (believe they do) have trickle down tech (ie..more poles) as newer designs were released. MIT lineage is sometimes hard to understand but I believe you might find a positive difference. I made a similar switch based on Joe Abrams (MIT reseller) suggestion.➀Speakers: Polk1.2tl's (Uber Mods) ➁Pre/Amp/DAC: PS Audio PMG Signature Pre, BHK Signature 250, PMG Signature 512 ➂Cables/IC's: MIT S1Bi-Wire/S1 Balanced +Avel Lindberg 1000VA "Dreadnought" ➃Power Conditioner: PS Audio P15 Power Plant ➄Power Cords: Core Power Technologies Gold, DH Labs Power Plus DIY w/Neotech NC-P301 & P311ends ➅Streaming: Roon ROCK on wifi'd NUC, TP-Link WAP, & Uptone EtherREGEN, AfterDark, Emperor Double Crown Clock, Black Modernize LPS⟿Ω☯☥☮⟿🔊♩♪♫♬♩♪♫♬♩♪♫♬ -
@JayCee
I already have the S1's on the left and right front yes. I had and an older white MI-330 plus series two for the center channel and a Kimber Hero for the back surround. Now the S2's are on the center and back surround coming off of the multichannel outputs of the Oppo UDP-205. -
Cool. After I posted the first time I had a DOH moment. Glad you're enjoying them!➀Speakers: Polk1.2tl's (Uber Mods) ➁Pre/Amp/DAC: PS Audio PMG Signature Pre, BHK Signature 250, PMG Signature 512 ➂Cables/IC's: MIT S1Bi-Wire/S1 Balanced +Avel Lindberg 1000VA "Dreadnought" ➃Power Conditioner: PS Audio P15 Power Plant ➄Power Cords: Core Power Technologies Gold, DH Labs Power Plus DIY w/Neotech NC-P301 & P311ends ➅Streaming: Roon ROCK on wifi'd NUC, TP-Link WAP, & Uptone EtherREGEN, AfterDark, Emperor Double Crown Clock, Black Modernize LPS⟿Ω☯☥☮⟿🔊♩♪♫♬♩♪♫♬♩♪♫♬
Yes I am thank you. Now I have all MIT coming out of the Oppo.
I loves me some MIT, but they're effing EXPENSIVE -
Garage #2: Cambridge Audio EVO150 Integrated Amplifier, Polk L200's, Analysis Plus Silver Oval 2 Speaker Cables, IC's TBD. -
A likely excuse sir!!
@verb Have a look at when this thread was started..................... -
Dang! I completely missed it! Well, at least I'm happy for you Carlton!
