MIT Shotgun 2 Interconnects - 2 meter great shape
$280 per pair Shipped double-boxed with original box, packaging and all literature p1voqsy3t4ui.png
    nooshinjohn Posts: 25,985
    How many pairs do you have?
  • NotaSuv
    NotaSuv Posts: 3,871
    just the one pair
  • kevhed72
    kevhed72 Posts: 5,157
    PM coming later.....put me in line!
  • dorokusai
    dorokusai Posts: 25,576
    Lifelong MIT fan. Although I stopped after the Magnum series. I can only hear so much. I did however purchase some Oracle jumpers for my Magnepan 3.6R.
  • Are they still available?
  • NotaSuv
    had one express interest but have yet to hear back from them...…..
  • kevhed72
    Im going to pass....just found a demo phono pre. GLWS
  • NotaSuv
    SOLD these are no longer available
  • Got them and hooked them up to my Oppo.
    Definitely a difference between this one and the older white colored MIT cable I was using. Better integration between the channels. I have some S1 cables for the left and right and I am using these S2’s for the center and back surround.
    Thanks much John!👍🏾
  • JayCee
    JayCee Posts: 1,509
    edited November 2019
    ...older white colored MIT cable I was using. Better integration between the channels. I have some S1 cables for the left and right and I am using these S2’s for the center and back surround.
    Try the S2's in place of the older white S1's you have on the fronts (L/R). The newer S2's should (believe they do) have trickle down tech (ie..more poles) as newer designs were released. MIT lineage is sometimes hard to understand but I believe you might find a positive difference. I made a similar switch based on Joe Abrams (MIT reseller) suggestion.
    Speakers: Polk1.2tl's (Uber Mods) Pre/Amp/DAC: PS Audio PMG Signature Pre, BHK Signature 250, PMG Signature 512 Cables/IC's: MIT S1Bi-Wire/S1 Balanced +Avel Lindberg 1000VA "Dreadnought" Power Conditioner: PS Audio P15 Power Plant Power Cords: Core Power Technologies Gold, DH Labs Power Plus DIY w/Neotech NC-P301 & P311ends Streaming: Roon ROCK on wifi'd NUC, TP-Link WAP, & Uptone EtherREGEN, AfterDark, Emperor Double Crown Clock, Black Modernize LPS⟿Ω☯☥☮⟿🔊♩♪♫♬♩♪♫♬♩♪♫♬
  • JayCee
    JayCee Posts: 1,509
    JayCee wrote: »
    I may have misread what you changed. After rereading it looks like you might already have newer S1's on the fronts?
  • @JayCee
    I already have the S1's on the left and right front yes. I had and an older white MI-330 plus series two for the center channel and a Kimber Hero for the back surround. Now the S2's are on the center and back surround coming off of the multichannel outputs of the Oppo UDP-205.
  • JayCee
    JayCee Posts: 1,509
    Cool. After I posted the first time I had a DOH moment. Glad you're enjoying them!
  • Yes I am thank you. Now I have all MIT coming out of the Oppo.
    I loves me some MIT, but they're effing EXPENSIVE
  • I'm just surprised @verb didn't get these before I could get my greasy grabbers on them! ;):D
  • verb
    verb Posts: 10,176
    Lol! Was out of town the past few days! :smile:
  • verb wrote: »
    A likely excuse sir!! :p
    @verb Have a look at when this thread was started.....................
  • verb
    verb Posts: 10,176
    Dang! I completely missed it! Well, at least I'm happy for you Carlton! :smile:
