Are 900LS suitable for rear channels
As the title suggests, I am wondering if the 900LS is a reasonable option for rear channels (6 and 7) for the 7.1 portion of the hometheater I am putting together. I was going to use 700LS x6 for in-ceiling atmos speakers and then further back the 900LS. I would use the 500LS x6 for atmos, but everyone seems to be out of them aaaaand the 700s are 147 each from amazon (not FULFILLED by amazon). The other option i was thinking of were the Revel C763L (I can get a really good deal on them) because they were "angled at the listener" shall we say. Here's a quick link for reference so you understand what I am saying... https://www.crutchfield.com/p_265C763LA/Revel-C763L.html?tp=193
They will sit at the same height (about 12ft) as the atmos dedicated units (700s)
I have to genuinely wonder though, how critical is this? The angle that is. How much info is REALLY coming out of those channels and is the slight angle of the Revels REALLY going to make that difference to my ears? I'd rather have a system that is more closely matched in terms of drivers and more specifically those ring radiators I love so well.
For reference, fronts are M707s, sides are 265LS, center is an older but MASSIVE Paradigm. As such in this scenario, everything, assuming I went with the 900s, would be Polk short of the center, which at 70# and pushing 4ft wide is fairly stout.... and kinda unique.
Any input is welcome, this is a big, and kinda pricey, decision.
THX yall
  • natronforever
    For the money, I'd consider using the 700-ls for rear surround, as well as the in ceiling atmos. Then, grab yourself a Lsim-706 or 704 center channel while they're heavily discounted, to have a more cohesive collection. Sounds like you love that beast of a paradigm, though.
    From what I understand of atmos, you would only want an angled speaker if your ability to place the in ceiling atmos speakers was compromised. If you're able to place the in ceiling atmos speakers as per Dolby specifications, then I'd just get a non angled speaker, such as the 700-ls.
    Good luck!
    Main: Polk Rti-38
    Center: Polk Csi-40
    Rear: Polk Fxi-30
    Sub: SVS PB10-isd
    Receiver: Marantz SR-5007
    Buttkicker Mini Concert x 4
    nooshinjohn Posts: 26,064
    edited September 2019
    There is not enough information out there yet for anyone to really say much. They were just launched yesterday, but based on the product description, I would say no in this case.
  • WLDock
    WLDock Posts: 3,073
    Graboids wrote: »
    Of course for the best effects you'll want to follow Dolby's recommendations. The FRONT, SIDE, and REAR speakers should be at ear level....or the REARS should be no more that 1.25 times the height of the front. They don't recommend the rears in the ceiling if you can prevent this.
    As far as the height speakers, its all about using a wide dispersion timber matched speaker mounted at the right angle to the listing position. For sure something to consider given your 12ft tall ceiling. Polk does not give any off-axis data so its a guess on the dispersion of the 700-LS.
    Also I agree on picking up the LSiM706c center that currently on sale. Its a very capable beast of a center and will be timber matched to your LSiM707's. The BIG Paradigm centers are cool and maybe its not a huge difference if you keep it. However, if timber matching betters the experience even a little it might be worth it. Only you can decide. I liked the LSiM706c better than the massive CS1000p center with built-in powered subwoofers that I had! If that's worth anything... I found the 706c to be more refined and detailed with good controlled low end.
    CS1000p - 34"w x 14"d x 8.6"h - 55.9 lbs !!!
    https://www.dolby.com/us/en/technologies/dolby-atmos/dolby-atmos-home-theater-installation-guidelines.pdf
    http://www.acousticfrontiers.com/dolby-atmos-dispersion-requirements-for-ceiling-speakers/
    https://www.cepro.com/article/5_crucial_tips_for_dolby_atmos_setups_5_best_demo_scenes
    Post edited by WLDock on
  • WLDock
    WLDock Posts: 3,073
    The OP was referring to these: :)
    Not that the new L800 was referenced but....for the record... Polk stated that one could go "ALL IN" with SDA in the rear for an immersive experience. $6K rear channel.... only heavy deep pockets hitters need apply. LOL! https://youtu.be/LrrNZJrT_CI?t=734
