I have a set of RT-12 towers that I am attempting to restore?
alaskadean
in Speakers
The cones appear intact, but the gaskets are torn and need replacing. Speakers weren't blown, but my cats pulled off the cover to access. Are there kits to replace gaskets and perhaps replace the cone if damaged? Just starting to explore and seeking direction. Thanks
Answers
Find a used driver. Go to parts express for gasket material.
alaskadean wrote: »The cones appear intact, but the gaskets are torn and need replacing. Speakers weren't blown, but my cats pulled off the cover to access. Are there kits to replace gaskets and perhaps replace the cone if damaged? Just starting to explore and seeking direction. Thanks
By gaskets I'm guessing you actually mean the surrounds as there's no way for a cat to access the gaskets unless the drivers are removed from the cabinet. Therefore, the answer is there are no surrounds available. As pitdogg2 suggested, look on eBay for replacement drivers.Political Correctness'.........defined
