Are these Polk SDA 1???
Hello fellow polkaholics. I have come across a set of Polk speakers that the owner has identified as Polk SDA 1. Any advice on what to look out for, opinions on this Model # and what would be the going price for a nice set? Thanks for your input.
  • Nightfall
    Nightfall Posts: 10,084
    Make sure none of the woofers are frozen, the tweeters work, and none of the rubber surrounds are torn.
    afterburnt wrote: »
    Village Idiot of Club Polk
  • Nightfall wrote: »
    Thanks for the advice.
  • DaveHo
    DaveHo Posts: 3,580
    edited August 2019
    Model 1C. Drivers look correct from what I can see. $300-$400 for a stock pair would be a fair price if the SDA cable is included. Maybe a little more if mint.
  • DaveHo wrote: »
    Thanks DaveHo, The interconnect cable is included and not in mint condition. Will be looking at them tomorrow and hope to get them.
  • verb
    verb Posts: 10,176
    DaveHo wrote: »
    I have a set of 1C's as part of my secondary rig. And, another set WIP completely upgraded. Love em! :)
    F1nut Posts: 51,673
    The side panels are coming off, but the drivers and PR's are very clean.
  • I have a set of 1C's as part of my secondary rig. And, another set WIP completely upgraded. Love em! :)[/quote]
    Thanks for the input verb
  • ultrasoudproductions
    edited August 2019
    Thanks for the input F1nut, but can you lell me what PR's are? Sorry for not knowing the lingo. LOL I am a bit concerned about the white over smear around the tweeters. Is that common?
    F1nut Posts: 51,673
    Passive radiator.
    The tweeters are the nasty SL2000. You'll want to replace them with the RD0194 immediately.
  • skrol
    skrol Posts: 3,437
    In layman's terms, the PR is the big round flat one at the bottom. It is "passive" in that it is not driven my electrical energy in a voice coil. Instead the pressure changes in the cabinet from the driven speakers (4 mid-woofers) causes the PR to move (resonate) and produce sound at lower frequencies. For it to work properly, the cabinet needs to be sealed. Otherwise, the pressure escapes and doesn't drive the PR.
    So that is another thing to check. Make sure that the edges and corners are not cracked. You can gently press and hold the PR in and the mid-woofers should move outward and slowly return to their resting position. If they return quickly or don't move at all, then there is a problem; either the cabinet has a leak or the mid-woofers are locked.
    Stan
    Main 2ch:
    HT:
    Other stuff:
