DVD player output mod, help needed
Mr. Sharpe
I have a Denon DVD-2800 I want to add a balanced output stage to with a separate switched power supply. I already know where to attach the extra power supply to have it switch on and off with the player.
I'm looking at simple unbalanced/balanced output boards on eBay that have power input and signal inputs on them. No problem, Those are easy to understand. What's more difficult to get is how to use a supply with these boards. Would I use an actual power supply or just a transformer? I know input and output voltage is not high at all so I don't think I need a regulator. And using the players supply would be too easy. His doesn't have to amount to anything really fancy because I'm not spending much on it.
If you're wondering why I want to do this to the player is because I hate seeing all the extra space in there go to waste and i want a cool project to do:)
Home theater:
43” Westinghouse Displayer
Marantz UD-7007 Player
Emotiva MC-700 Processor
Adcom GFA-5006 Amplifier
Parasound Zamp Amplifier
Ethereal ESO-1 Power Conditioner
Klipsch RC-10 Center
Klipsch R34c Fronts
Klipsch RB-41 Surrounds
Polk audio PSW-505
Stereo:
Polk audio RTA-12c’s fully upgraded crossovers
DIY 12tc braided speaker cables
Denon DVD-5910ci Spinner
Parasound P6 Preamplifer
Parasound HCA -1500a Amplifier
Klipsch R34c Fronts
Polk audio PSW-505
Stereo:
The simplest way to derive a balanced output would be by adding an op-amp configured as a unity gain invertor buffer. You would just need one op amp per channel, preferably the same type as the one's in the analog output section. You could power them from the same power supply. There is a better way but it is somewhat more involved.
Ok, what is the more involved way?Home theater:
Klipsch R34c Fronts
Polk audio PSW-505
Stereo:
Parasound HCA -1500a Amplifier -
A complete redo of the analog stage following the dac chip's.
Well That player had all kinds of chroma bug problems from the start. That is why there is a 2800II and that one didn't last long either as the 2900 came out on it's heels. I sure wouldn't dump much money into it IMHO. Why not look for a player that already has that section?
Lol ewWell That player had all kinds of chroma bug problems from the start. That is why there is a 2800II and that one didn't last long either as the 2900 came out on it's heels. I sure wouldn't dump much money into it IMHO. Why not look for a player that already has that section?
I wasn’t planning on spending much more than $30 or so. I know about the chroma issues but the player works and I don’t really want to get another one. The only way I see this one going is though the garbage or a thrift store.
So using something like this https://www.ebay.com/itm/Assembled-DRV134PA-dual-channel-single-ended-balance-board/222441370583?_trksid=p2504926.m5232.l9681 hooked to the players supply and signal output isn’t really an option?Home theater:
Klipsch R34c Fronts
Polk audio PSW-505
Stereo:
You should be able get that to do what you want. It's more complex then need be but should work.Mr. Sharpe wrote: »
Haha I’ll try it. I may even try one of the others that don’t have the plugs on them already. Then maybe try the supply thing later onHome theater:
Klipsch R34c Fronts
Polk audio PSW-505
Stereo:
That board already has a full power supply minus the transformer. You simply need to feed it an appropriate AC voltage. Powering it from transformer powering the analog section should be doable. Or feed it an unregulated DC from the analog supply.
Oh cool that’s what I was hoping you’d say to begin with:-) since I could use the players supply I see four wires going into the analog board, which should I use? When using my multi meter there are three wires with voltage but one is ever changing and the other two are something like 6 and 8v and then there’s ground, are those the ones I connect to this board?
Home theater:
Klipsch R34c Fronts
Polk audio PSW-505
Stereo:
You need either two wires with 12-18 volts AC or plus and minus DC >15volts or so.
If not then you are out of luck. The meter is likely fluctuating because your measuring AC with the meter set to measure DC. I will try to find a schematic later this evening. -
That’s where I get lost:( my meter only has a dial for volts, not either ac or dc so that sucks. I haven’t attempted this project yet because I did t want to do it and fry my preamp or something lol
Man everything you could help me with on this I am extremely appreciative!Home theater:
Klipsch R34c Fronts
Polk audio PSW-505
Stereo:
Mr. Sharpe wrote: »That’s where I get lost:( my meter only has a dial for volts, not either ac or dc so that sucks. I haven’t attempted this project yet because I did t want to do it and fry my preamp or something lol
Guarantee that there's a selection for AC vs. DC voltage.
OK, I'd be very, very surprised if not.
Show us a photo or give us a mfgr name & model number.
Sometimes the AC vs. DC are represented graphically, thus.
(random. borrowed image
AC voltage(V) and, on this meter, current (A) is indicated by the "tilde" (squiggle), ~
DC is indicated by the solid line over the dashed line.
We're here for ya, buddy!
edit: OK, it looks like some meters nowadays may auto-detect AC vs. DC
Who knew?!?
Ok it looks like there is + and - 12 volts DC feeding the analog section. Assuming your using the PC board you linked to,this is a bit too low of voltage to allow the regulators on the balanced board to operate correctly. I would remove the two 12 volt regulators on the new balanced board. (the black 3 pin transistor looking things.) Then you would need to feed the regulated voltages from the analog output board or from the power supply board to your new board. There should be an easy access point somewhere.
Here’s the mere I have. I have another one that takes a 9v but not sure if it works, it’s old.
Sounds simple enough and again I really appreciate you helping me out, I hate to seem lazy too, I think I just needed pointing in the right direction I.e away from the service manual 😂
Home theater:
Klipsch R34c Fronts
Polk audio PSW-505
Stereo:
Put it on “A” then pushing the range button should toggle you between AC/dc
Should see a symbol change on screen
Also, when was the last time you changed the battery
Low batteries will give you false readings2-channel: Modwright KWI-200 Integrated, Dynaudio C1-II Signatures
I’ll do just that, I don’t think I’ve ever done it before and can’t recall if I had a instruction book.
Oh no they’re old lol you can turn it on and it’ll read an almost constant change in bolts without putting it to anything hahaHome theater:
Klipsch R34c Fronts
Polk audio PSW-505
Stereo:
