What should I be looking for?
Well as some of you may know my B&K amp blew something while i was watching a movie. I haven't had a chance till tonight ro open it up. Any pointers on what I should be looking for? I've already check all the fuse. Can't tell if anything is blow based on my initial looking around in there. Here is a picture of it with the lid off. Maybe it was the dust that killed it. Didn't know it was that bad in there. Now I'm going to open up all my amp and blow everything out. pc1lbvcg3x69.jpg
Epson 3020 projector. Da Lite screen. Oppo 103. Yamaha CXA5000. B&K 7250ii. HSU VTF2. Def Tech Supercube 4000. Polk Rtia9 CsiA6 FxiA6. Monster hts 2600. Home theater.
Bedroom consist of NHT model 2 powered by Parasound hca1200ii coming from my computer.
Stuff laying around. Too much to list but don't want to sell either.
    What you should be looking for...is a good tech to take it to. Get an estimate, then decide if it's worth fixing or just buy another amp.
  • DaveHo
    DaveHo Posts: 3,583
    How did you check fuses? Looking at them is not a good way. Use a multi-meter to verify continuity.
