DSW Pro 600 Repair
Hello,
Is it possible to get repair or disassembly instructions for a DSW PRO 600 sub?
I purchased the replacement amp back plate but it will not operate with the existing IR or BLUE LED for the logo backlight.
So, I need to have access to the blue LED? Can the blue LED be installed from the front? With the logo assemble pry out forward or do I need to disassemble the complete unit?
Same for the IR sensor but I think I ca get to that from the rear.
Any help would be great...
    F1nut Posts: 51,940
    Your best bet is to call or email Polk about the issue.
  • jjpann
    jjpann Posts: 4
    I did they offer no assembly instructions thus my post.
    F1nut Posts: 51,940
    Ok, well I don't know of anyone here that can help you with your questions.
  • jjpann
    jjpann Posts: 4
    Isn’t this a Polk forum?
    F1nut Posts: 51,940
    Yes, but the Pro 600 is an older sub and I don't believe a popular one, so there aren't any members here that own one as far as I know. Since you can't figure things out perhaps a professional repair shop is in your future.
    Toolfan66 Posts: 18,156
    I owned a 500 and 600, both went out shortly after the warranty past, Polk still helped me out with the amps, but I finally upgraded to a real sub, and gave the kitty litter subs away...
    SVS....... \.,,/
  • jjpann
    jjpann Posts: 4
    edited July 2019
    Thanks appreciate the comments. The Pro 600 replacement 660 is available today so not a really issue of obsolescence...,it was just surprising the IR and Logo backlight were not compatible as this would have made the repair a no brainer.
