In case you want to add harmonics (i.e., distortion) to your (tube) hifi, here's just the thing
mhardy6647
mhardy6647 Posts: 35,507
edited July 2019 in 2 Channel Audio
https://highend-electronics.com/products/shun-mook-signal-tube-resonators
* Reduces total harmonic distortion
* Damping of tube glass resonance and ringing
* Filters electromechanically vibrations
* Adds rich musical harmonics to its output signal
B)
so... does it add or reduce harmonics?
  • Wardsweb
    Wardsweb Posts: 944
    Psychoacoustics: if you think it's real, it is. Perception is reality.
  • lightman1
    lightman1 Posts: 10,800
    Heavy thoughts, Luther.
    heiney9 Posts: 25,629
    Even order harmonics tend to be more soothing than odd order harmonics. So?
  • delkal
    delkal Posts: 764
    Not that African Mpingo wood again. So how does this reduce harmonic distortion but add harmonics at the same time?
    One company sells little hockey pucks of it for about $50-100 each that you are supposed to put on special holders all around your room (the more you buy the better). This wood soaks up all of the bad sounds and makes your system sound better. Who knew this wood is so good it can soak up the bad electrical signals too.
  • BlueFox
    BlueFox Posts: 15,250
    A semi-conductor works best to eliminate tube harmonics.
    THD - total harmonic distortion
    TIM - Transient intermodulation distortion
  • Osarion
    Osarion Posts: 194
    heiney9 wrote: »
    A few more they can add to the marketing:
    LOL!!
    WTF??
    B.S.!!!
    F1nut Posts: 52,294
    Total harmonic distortion (THD) is a measurement that tells you how much of the distortion of a voltage or current is due to harmonics in the signal. THD is an important aspect in audio, communications, and power systems.
    Transient intermodulation distortion, or TIM, occurs in amplifiers that employ negative feedback when signal delays make the amplifier incapable of correcting distortion when exposed to fast, transient signals.
    There's nothing LOL, WTF or BS about either.
  • joecoulson
    joecoulson Posts: 4,969
    STFU
  • Osarion
    Osarion Posts: 194
    Those weren't meant for THD and TIM I was poking fun at the African Mpingo wood. I've heard systems using it, though not this particular product. It's always fun to say African Mpingo!
  • delkal
    delkal Posts: 764
    edited July 2019
    So is it Emmpingo or Ummpingo or Mmmpingo........or is the M silent so just Pingo wood?
    lightman1 wrote: »
    he's a heavy guy.
    Wait, let me rephrase that...
    I mean metaphorically.
    like... umm... in-a-gadda-da-vida heavy, I mean...
    B)
    delkal wrote: »
    M as in the O in opossum, methinks.
  • Osarion
    Osarion Posts: 194
    delkal wrote: »
    That's the way I've always heard it said, just Pingo. I like to add some flavor so it's Muh-Peeeeeeeng-Oooooohh!!
    at least it's not !pingo B)
  • Osarion
    Osarion Posts: 194
    Is that the symbol for the click sound? If so you win this thread!! But I guess since you started the thread you win it by default haha!
  • VSAT88
    VSAT88 Posts: 1,379
    edited July 2019
    delkal wrote: »
    Ok so I should try to fit an Opossum into the Fisher 500C chassis or use 4 as feet ? I have quite a few round here in Alabama so I could try on the wall, in the corners....
    edited July 2019
    Osarion wrote: »
    yes. the click.
    B)
    VSAT88 wrote: »
    delkal wrote: »
    I think they could provide good damping -- they'll help keep ticks out of it, as well, which could be a plus.
  • VSAT88
    VSAT88 Posts: 1,379
    Osarion wrote: »
    yes. the click.
    B)
    VSAT88 wrote: »
    delkal wrote: »
    Ticks or Clicks ???? ^
    whadda I look like, some kinda Noam Chomsky kinda ethnolinguist or what? ;)
    I thought it was the clicks, like the !Kung
    https://en.wikipedia.org/wiki/ǃKung_people
    hunh?! I've never heard/heard of that before!?!
    Cool.
    Thanks for postin'
    B)
