My DirectTV remote suddenly doesn't turn volume down on Soundbar3000...how fix?
Looks like this problem is not unique to me but I haven't received any solutions yet.
Answers
  • ginopazz
    Any help please?
  • Mattox86
    Mattox86 Posts: 65
    Does it turn the volume up? Will the remote turn other devices volumes down?
  • Eep
    Eep Posts: 9
    I have the Omni SB1 Plus and, if it loses power (unplugged or power outage), the remote control (and any paired remote) stops working and I have to hold down the sound bar's power button for 10 seconds to force-reset the sound bar. It's a pain but I've found it's the only way to get the remote to work again. Unfortunately, the sound bar will need to be re-setup for wireless networking and any other remotes programmed for volume, mute, power, etc.
    Subwoofer static causes bass "thumping" too--I have to turn off the sub at night in order to sleep. Plus the sub and sound bar don't seem to have an auto power-off after a certain amount of inactivity.
    Also, can't wire satellite speakers--only wireless. Such a bad design the Polk Omni SB1 (and Plus, which I have) is!
