LSi9/7 System reciever
Pandler65
Need some help here on purchasing a new receiver for my LSi9,LSi7, LSi Center system. I am upgrading my old Pioneer receiver that has a blown amp. Right now I am looking at Denon 4500H, Marantz 6013, and Pioneer SC701. Having asked around about power requirements to drive these 4 ohm monsters I am being pushed toward another Pioneer like the SC701 due to the power and efficiency of the Class D3 amps. On my old SC1523 I was not impressed with MACC calibration and much preferred my Audessey Cal on my Onkyo in the Den. My Heart is thinking the Marantz which has AB amps, but do I need the power of the Pioneer D3 amps to get the most from these speakers.
Any thoughts are greatly appreciated,
Any of those receivers will drive them, but it will be strained, which is possibly why you have a blown amp. You need an external amp to get the most out of those speakers, even if just a 2 channel for the mains. My suggestion would be to take a step down on the receiver and use the extra money for a good used two channel amp.Living Room 2.2: Usher BE-718 "tiny dancers"; Dual DIY Dayton audio RSS210HF-4 Subs with Dayton SPA-250 amps; Arcam SA30; Musical Fidelity A308; Sony UBP-x1000es; Squeezebox Touch with Bolder Power Supply
Bedroom 2.1Cambridge Azur 551r; Polk RT25i; ACI Titan Subwoofer -
A separate 2 channel amp at least for the front left and right, let any of those receivers drive the rest.HT SYSTEM-
lsi 9's -
What Rooftop said! Welcome to Club Polk Pandler.Marantz AV-7705 PrePro, Classé 5 channel 200wpc Amp, Oppo 103 BluRay, Rotel RCD-1072 CDP, Sony XBR-49X800E TV, Polk S60 Main Speakers, Polk ES30 Center Channel, Polk S15 Surround Speakers SVS SB12-NSD x2
Unless you NEED the extra channels, the denon 3500 or marantz 5013 would be fine with a good two channel amp. I would go with the denon, slightly more neutral and forward sounding to balance out the warm and laid back LSis.Living Room 2.2: Usher BE-718 "tiny dancers"; Dual DIY Dayton audio RSS210HF-4 Subs with Dayton SPA-250 amps; Arcam SA30; Musical Fidelity A308; Sony UBP-x1000es; Squeezebox Touch with Bolder Power Supply
