Tweeter brackets for my 1C's
Are there any tweeter brackets floating around out there for 1C's?
I currently need enough for all four tweeters.
Except for rewiring the interior that is all that is left to completely rebuilding them.
Denon AVR X4200W
Parasound A23 amplifier
LG 65" Ultra HD4k
LG 4kBR - UP970
Denon DVM 4800
Denon DP 3000 turntable
Saec 308sx tonearm w/
Dynavector 10x5 cart
Vincent PHO 701 Phono Preamp
MIT Avt3 Speaker c's
Audio Quest Big Sur ic's
Polk SDA 1C's modded
Polk LSim 707
Polk LSiM706c
Polk RTiA 3's
Polk 80F/X-RT
Polk DSW PRO 440wi sub
Infinity bu2 sub
"The early Klingon gets the Gagh"
    Tony M Posts: 11,566
    edited June 2019
    Do you mean "Larry's Rings" tweeter plates?
  • Manticore
    Manticore Posts: 408
    Tony M wrote: »
    Why yes i do.
    Larry found me a set of his rings being sold by someone else. So all speakers have the rings except the tweets.
    Denon AVR X4200W
    LG 65" Ultra HD4k
    LG 4kBR - UP970
    Denon DVM 4800
    Polk LSim 707
    Polk LSiM706c
    Polk RTiA 3's
    Polk 80F/X-RT
    Infinity bu2 sub
    F1nut Posts: 51,656
    You could use Hurricane nuts on those.
  • Manticore
    Yes i could but, im not sure if its being anal or OCD one of which prevents me from doing so :o
    Denon AVR X4200W
    LG 65" Ultra HD4k
    LG 4kBR - UP970
    Denon DVM 4800
    Polk LSim 707
    Polk LSiM706c
    Polk RTiA 3's
    Polk 80F/X-RT
    Infinity bu2 sub
    F1nut Posts: 51,656
    If it helps, the tweeter brackets are not much different than Hurricane nuts.
  • Manticore
    Correct they are similar. I guess its my OCD. I will have to make sure the same screws are used. I guess PE carries the hurricane nuts?
    Denon AVR X4200W
    LG 65" Ultra HD4k
    LG 4kBR - UP970
    Denon DVM 4800
    Polk LSim 707
    Polk LSiM706c
    Polk RTiA 3's
    Polk 80F/X-RT
    Infinity bu2 sub
    F1nut Posts: 51,656
    Yes
  • Manticore
    Thanks !!
    Denon AVR X4200W
    LG 65" Ultra HD4k
    LG 4kBR - UP970
    Denon DVM 4800
    Polk LSim 707
    Polk LSiM706c
    Polk RTiA 3's
    Polk 80F/X-RT
    Infinity bu2 sub
    pitdogg2 Posts: 26,915
    I have screws if you need.
    Toolfan66 Posts: 17,978
    Let me see if I can dig up 4 sets...
  • Manticore
    Toolfan66 wrote: »
    This is what separates this forum from others.
    @pitdogg2 i have located and ordered the same screws already used on my speakers last night. Thanks for your offer.
    @Toolfan66 Larry i know your busy working on the house and everything else life throws at us all. If you can locate them great, it would be genuinely appreciated!
    Denon AVR X4200W
    LG 65" Ultra HD4k
    LG 4kBR - UP970
    Denon DVM 4800
    Polk LSim 707
    Polk LSiM706c
    Polk RTiA 3's
    Polk 80F/X-RT
    Infinity bu2 sub
  • Manticore
    Pm sent with brief message.
    Denon AVR X4200W
    LG 65" Ultra HD4k
    LG 4kBR - UP970
    Denon DVM 4800
    Polk LSim 707
    Polk LSiM706c
    Polk RTiA 3's
    Polk 80F/X-RT
    Infinity bu2 sub
  • Manticore
    Toolfan66 wrote: »
    Shipped!!
    As i said above: This is what separates this forum from others.
    A big Thank You to Larry for digging through the muck and finding these for me. I will always appreciate it!!
    Denon AVR X4200W
    LG 65" Ultra HD4k
    LG 4kBR - UP970
    Denon DVM 4800
    Polk LSim 707
    Polk LSiM706c
    Polk RTiA 3's
    Polk 80F/X-RT
    Infinity bu2 sub
  • dromunds
    dromunds Posts: 10,091
    I will always know Larry as an outstanding human being for what he has done JUST for us on this Polk Forum. Lord knows what he does for others must be just as honorable.
    I'm a VERY LUCKY winner of one of Larry's Karmas. It being a set of SDA-SRS2 "Larry's Ring Set". W/free shipping also! I still(!) owe you a fine lunch Larry!
    Thanks' again Larry! ;)B)
  • Manticore
    Larry, the tweeter brackets arrived safe and sound. They are a thing of beauty. I can now put my OCD to rest or at least give it a break for awhile!
    Thank you again for your generosity.
    If your ever up in the North East please let me know & don't hesitate to drop by for a visit!!!!! Lunch? Dinner? Swim in the pool? Cold ones a plenty!!!!!!!!!!!!!!!!!
    Denon AVR X4200W
    LG 65" Ultra HD4k
    LG 4kBR - UP970
    Denon DVM 4800
    Polk LSim 707
    Polk LSiM706c
    Polk RTiA 3's
    Polk 80F/X-RT
    Infinity bu2 sub
    audioluvr Posts: 5,861
    Manticore wrote: »
    I love the fact that "anal" isn't blocked but other stupid **** is. Like your new avatar by the way...
  • Manticore
    I'm guessing vanilla likes anal? Never mind I'm not going there. >:)
    Its actually an album cover i found somewhere. It seemed fitting for the site where so many are Polkaholics!
    Denon AVR X4200W
    LG 65" Ultra HD4k
    LG 4kBR - UP970
    Denon DVM 4800
    Polk LSim 707
    Polk LSiM706c
    Polk RTiA 3's
    Polk 80F/X-RT
    Infinity bu2 sub
