Wtb Dreadnought
ddog
Looking for a Dreadnought...
If you have one for sale please let me know.
Thanks in advance.
Thanks in advance.
I think Sean is selling his 800v, @ptrooper- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
Thanks in advance.
Ok perfect..I'll send him a message.
Do you know if that has the same hookup has the one's you used on the crossovers you built for me..?
Thanks for the heads up.. -
Yes, I built his crossovers- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
It was sold... I'm still looking for one..
Not sure which connections you are looking for on it but I have a 800v model with Neutrik Speakon connectors, if interested shoot me a pm.
Danny -
Yeah I think that's the same connects I have. VR3 built my crossovers for my 3.1's.
Hiw much you thinking? -
You just need to make sure you are using all 4 of the conductors of the speak on, fwiw- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
Danny
I'm interested..
Shoot me a PM please -
I'm knew to this... so to be clear with his box all I'll need is another cable..right? -
Depending on how he wired it, you would need to make sure he used all four conductors, then cut your cable in half and add connectors- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
Ok...I get it now..
So this is what I need so I won't have to worry about whether on not my amplifier is a non common ground...?
Sorry for all the questions..
I have a Simaudio Titan ht-200 7ch amplifier by Moon that I want to put in the system.
I'm not sure if it's a common ground and I haven't heard back from Moon..
Thanks -
Yes but alot of folks notice an improvement regardless- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
Ok ... sounds good..
Oh and man the crossovers are really opening up..!
They are sounding better every day. -
Great to hear! 😁- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
I followed how Jesse wired his and I believe I only used two of the pins. I'd have to open it up and take a peak or @F1nut may know from memory.
His memory is pretty well shot, but he does still carve notes on his cave walls, so I think he will be able to come up with the answers.I followed how Jesse wired his and I believe I only used two of the pins. I'd have to open it up and take a peak or @F1nut may know from memory.
On his mods, his sda cable uses all four pins- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
Mine, I see no reason to use 4 connections, but no harm in doing so.
President of Club Polk -
Man...that's a big ol transformer!!
I sure wish I could've got in on that gb!
@Gerres26 ...PM sent..
I'm interested..
