Wire Length
BossHog
BossHog Posts: 16
I often read that speaker wires should be cut to the same length to improve sound quality. My question is...should all speakers have the same length wire regardless of distance or only PAIRS of speakers. Example..both fronts L/R have 8 ft of wire each and both surrounds have 5 ft each.....or should all speakers use same length, 8ft?
Regards
  • Airplay355
    Airplay355 Posts: 4,298
    edited January 2005
    don't worry about it, the only way there would be a difference would be if the runs were like 50 ft to a 1 ft run, and even then you probably wouldnt notice.....5 feet and 8 feet arent even worth thinking about
  • gatemplin
    gatemplin Posts: 1,595
    edited January 2005
    Keep the wires as short as possible to reduce effects from inductance, capacitance, resistance and interference. End of story.
    Graham
  • Willow
    Willow Posts: 11,371
    edited January 2005
    ok....yes as mentioned keep them as short as you need them....but how are your rears shorter than your mains ? :rolleyes:
  • okiepolkie
    okiepolkie Posts: 2,258
    edited January 2005
    Hey willow, did you ever get the Harmony remote?
    Tschüss
    Zach
  • Willow
    edited January 2005
    should be pickin' that puppy up this weekend......I had bad CS from kameleon.....
  • okiepolkie
    edited January 2005
    Sounds good. Let me know how you like.
    (Sorry for the short thread hijack, I think I'm done)
    Tschüss
    Zach
  • Willow
    edited January 2005
    I will thanks....
  • BossHog
    BossHog Posts: 16
    edited January 2005
    Willow,
    My receiver is located behind my seating (the couch) and the surrounds located at the sides with mains beside the TV. Guess a new TV unit/stand is next on the list.
  • Willow
    edited January 2005
    It's what I thought.....all your cables to your TV run that long ?....
